How do you measure viewing area? at DVinfo.net
Alternative Imaging Methods
Old June 25th, 2005, 10:29 AM   #1
Is there an easy method of measuring the viewing area? I am trying to determine if I need to move in closer on the GG.
Leo Mandy is offline   Reply With Quote
Old June 25th, 2005, 01:09 PM   #2
you mean what size image you should be capturing? i believe its 18mmx24mm. cut that out of a piece of paper and measure your area with it.
Cody Dulock is offline   Reply With Quote
Old June 25th, 2005, 01:19 PM   #3
Shouldn't it be 36mmx24mm? Same size as a negative?
Wayne.
Wayne Kinney is offline   Reply With Quote
Old June 27th, 2005, 02:08 PM   #4
Depends on whether you want a still frame image size or a motion picture sized image. Unless you're using cine primes or something I see absolutely no reason to go with the smaller typical motion 35 size. So, short answer, yes, 36x24
Aaron Shaw is offline   Reply
