Finally, I've got Mini35 24p footage on line. - Page 2 at DVinfo.net
Alternative Imaging Methods
Old July 5th, 2005, 01:44 PM   #16
Looks great! Looks so good I'd hate it to get lost w/ that smudge. You can fix easily enough in After Effects or even in your editor.
I fixed it in the trailer.. here's what I did:
original : http://www.twodogfilms.com/fix/Image19.jpg
fixed : http://www.twodogfilms.com/fix/Image19-fixed.jpg
matte : http://www.twodogfilms.com/fix/matte.jpg
Either load your exported finished file, or put this in your existing edit (and then reexport - try to cut down on any many full compressions as possible).
Just load the matte image as an additional track. Set the composite mode to ADD and set the track opacity to 3 or 4% (experiment with this). I used a value of 2.5 and it's barely noticable (still there, but much better). Find a happy medium of balancing out too much bright and white and getting rid of the smudge.
If in doubt, here's a screenshot of what I had (ignore the 2nd entry on the timeline of your wmv file - I should have removed it (not needed)).
http://www.twodogfilms.com/fix/Image19-process.jpg
Best of luck!
PAL shooter in NTSC territory
Patrick Jenkins is offline   Reply With Quote
Old July 5th, 2005, 02:03 PM   #17
Originally Posted by Mathieu Ghekiere
Josh I already told you in another thread where you posted this, but I'm gonna say it again: beautiful work! Really!
Nothing short of beautiful!
And very professional results!
People who have you as DP are very lucky.
Thanks Mathieu! I actually was not the DP on these films though, I was the director. So, I should say that I am very lucky to have worked with the DPs I have. They've been great. I'm very involved with the visuals of the film but I have to give credit to them.
Wow Patrick. Thank you very much. I'm still very much in the editing phase, but when it comes time to color correct and master I'll look into your technique. Thanks for taking the time to do that. Much ablidged.
Josh Caldwell is offline   Reply With Quote
Old July 5th, 2005, 06:45 PM   #18
Not a prob.. hope it helps!
Old July 8th, 2005, 03:50 PM   #19
Originally Posted by Josh Caldwell
The first music cue is from Road to Perdition, which was composed by Thomas Newman.
For the audio, where the music pics up and becomes more epic sounding, what track or composer did that? I have to know, I can't get it out of my head. btw, great work!
Grant Tompkins is offline   Reply With Quote
Old July 10th, 2005, 04:53 PM   #20
It's by a band called E.S. Posthumous. The song is called Nara. You can check it out here: http://esposthumus.com/buy.html
Old July 10th, 2005, 06:58 PM   #21
very cool stuff. just bought the cd.
Old July 11th, 2005, 05:09 PM   #22
Josh,
Did you make the Mini 35 or you bought it?
Eniola Akintoye is offline   Reply With Quote
Old July 12th, 2005, 12:42 PM   #23
We rented it from TCS Inc. in NYC. Wish I could buy one...
