any questions about homemade 35-dv converter at DVinfo.net
Alternative Imaging Methods
Old June 11th, 2005, 10:05 AM   #1
hi
first. english dont's my born language. excuseme
i'm making a 35mm-dv converter with static groundglass
i have a problem. on the GG apear a circle more lighting. do how can resolve it.
i think to use a old +4 filter used however condenser lens. it's ok?
* the cam lenses take focus on GG without close-up lenses. it's ok?
* the cam record the images inverted. do i rotate 180d after?
thank you
saludos
Andresh Vazquez is offline   Reply With Quote
Old June 12th, 2005, 03:32 AM   #2
Hi,
I think this ought to be in the 'Alternative Imaging' forum.
JD
Jay Dee is offline   Reply With Quote
Old June 12th, 2005, 03:41 AM   #3
RED Code Chef
Thread moved to alternative imaging forum.
Rob Lohman, visuar@iname.com
Old June 12th, 2005, 05:06 AM   #4
Yes to all your questions. You got everything right, but if you need more information on those things, look for 'hotspot' or 'vignetting' on this forum. These are the terms for the lighter circle in the middle. Good luck.
Oscar Spierenburg is offline   Reply With Quote
Old June 12th, 2005, 07:12 AM   #5
ok. i will think it after to send it
solved yet
thank
Old June 12th, 2005, 04:24 PM   #6
the correct distance from condenser to GG is ...
the convex side to GG????
35mm lens(28-80)->condenser->GG->camlenses
thank
