#106 | |
#107 |
For some reason I was thinking something like a real-stream setup (even though you specifically said component). A component capture would be useful. Compression is something that is way more complicated than you are lead to believe since you can't just include a lib and make a function. Talking much more complicated at the level I'm working on and external chips require almost as much screwing around. I'm just not focusing on a component recorder. I'm focusing on something else just right now, but when thats done who knows.
www.engr.mun.ca/~wakeham/index.htm |
#108 |
I know what you are talking about. I just thought you were already working with somebody on that, and that a component version might be possible. What ever it is, keep it going.
Thanks Keith |
#109 |
I was working on something like that but not right now. Focusing on something else but if what I'm working on succeeds then I'll definetly be going after something like that next.
#110 |
Hmm... I would like to do something myself. I have some very good ideas, but my health doesn't permit me to do much.
#111 |
something may be to read
go here please
http://www.framos.co.uk/pdf_sheets/I...le_english.pdf Jenoptik is the famous reserach group, now the "iron curtain" gone back on the show |
#112 |
Looks good Ronald, what costings (and can this be plugged into any firewire port and be used by standard capture/edit software)? I have found it very hard to find a cheap mega-pixel firewire unit mostly a lot above $1000.
I've left you a message on the technical thread: http://www.dvinfo.net/conf/showthrea...241#post384241 Thanks Wayne. |
#113 |
The ccd can't read out fast enough for, it can only be clocked at max of 18mhz (5mp variant), which is essentially 18 megapixels a second at any bit depth, which even at 720p you can't hit 24fps, almost 20 but thats it without overclocking the ccd which will likely burn it out very quickly.
#114 |
Still that is not such a problem for me. 1280*545 (approx 2.35:1) = 16.7324, give those 16:9 digital TV purists their own black bars. Boy I must be desperate for a good RAW camera.
But, Keith, I am wondering, would the new Elpel 323 camera be good as a camera development platform? I understand it is re-programmable (even FPGA). If it is as cheap as the last camera you could get the camera and sensor, with FPGA compression engine, for around $700. That firmly beats all the other options in everything but capture software (and I don't know what will edit the compression format). A bit of FPGA'ing/reprogramming could make it record directly to a Ethernet external Hard drive case. Not to mention the possibilities of tapping the circuit for external display and control buttons. Anyway, this camera of Ronald's, do you know the costing, and if it can be used with standard capture/edit software through firewire? |
#115 |
I think everyone is desperate for a RAW camera. Their are just so many advantages. Its just like shooting RAW Digital stills. You have all the control of the image without having to pay a colourist. Thats Why I'm still working on stuff between school and my horrible luck. Even though I don't discuss it.
In theory you can reprogram the fpga for the elphel 323 but I'm pretty sure this is a combination job. The FPGA just feeds the processor and the processor handles all the issues of ethernet so its the firmware for the processor you would likely be needing to deal with not the fpga. The FPGA handles the compresseion algorithim though so if you wanted to change that then your back to fpga-land. If the camera is firewire than likely DCAM / IIDC spec so should be lots of capture software for it, more for mac based stuff from what i've seen.
#116 |
He He He.., new reports are cheaper Intel IBook in January, and wide-screen version ;) This is great news, we will see then.
By the way, how far are you off of announcing something, and do you have any sensor news that you have heard. I know cheap 720p Altasens, and sensor chips with dsp, compression and USB on board (phone market) are floating around. |
#117 |
This is totally unofficial so I'll keep it as vague as possible (Yes, I am a jerk)
The sensor is chosen and we're beginning intergration of it in a few weeks. Chosen with size, colour representation and shutter operation as the most important factors. To clarify earlier we have developed embedded hardware that allows hard drive recording without a computer. This has been the focus until it became reliable a few weeks ago. Their will not be compression in anything I design for a whlie, so its more hard drives for more data. Any computer connection is to get the data from the drives after it is shot - no computer for capture what so ever. Nice and vague if I do say so myself
#118 | |
I agree about the computer, I just had Windows XP working with around 1.9 MB of HD space free. No, I'm not a miracle system installer or anything, a couple of viruses turned up and I lost all my HD space. Now I am getting around to re-installing a 3rd part anti-virus and anti-hack tool, 56MB. I could make a Super Computer operating System with an feature set similar to Windows XP, and all the Office apps, in space like that, and completely virus/hack proof. Computers, gives me the willies now days. A CP/M guy said, we won't need more than 64K, Bill Gates, 640K is it, good grief what happened to them (the computer industry), 640MB is not enough to do what a 64K programmer could do in 10MB, and 3GB is hardly enough to do what a 6K programmer could do in 10MB. Good grief, they design like they are on a spaghetti farm, throwing cooked spaghetti against the wall to make electrical wiring circuits. Do you know, at an stage the first IBM PC was meant to be a Z-80 CP/M machine, and that after a year or two they were going to give us a Unix machine as the standard PC with Motorola processor, but the move to Unix was stopped. Boy did we loose out. |
