Here's a clip from my $50 mini35 at DVinfo.net
Alternative Imaging Methods
Old March 15th, 2005, 08:06 PM   #1
It has a non-moving plastic fresnel lens, but it's surprising how little grain there is. It shot through a GS400 in pro-cinema. Just put it together so I still need to tweak it some. I am using to much glass, three close-up filters in a row to get to +6, I need a +7 in a single filter. Lens is a 55mm Pentax.
http://rapidshare.de/files/886450/DOF2.wmv.html
To download, click the link. Scroll to bottom of the page, click "free". Scroll again to bottom of the page and watch the countdown timer, it's usually about a 50 second wait. When it's done, click download at the bottom and it will load.
(opps- make that $75 mini, I forgot the add the $25 m42 adapter)
Rokta Bija is offline   Reply With Quote
Old March 15th, 2005, 09:13 PM   #2
can we get a photo of the unit mounted to your camera?
- Shannon W. Rawls
Shannon Rawls is offline   Reply With Quote
Old March 16th, 2005, 08:32 AM   #3
That looks alright. Hopefully you'll take my criticisms in stride:
The colors seem a bit washed out -- what cam are you using? Objects "in focus" seem to be slightly unresolved. There's no real way to see the grain as there aren't any pans/tilts in your footage.
Otherwise, you could certainly shoot with it and your average viewer would never be the wiser -- it looks good, and pretty damn good considering the cost :D
- jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Jim Lafferty is offline   Reply With Quote
Old March 16th, 2005, 11:07 AM   #4
I'm having some trouble with my connection. Any chance of a still frame? I'm very interested.
Oscar Spierenburg is offline   Reply With Quote
Old March 16th, 2005, 01:00 PM   #5
The WMV file is pretty soft, the orignal capture is sharper.
This morning I adjusted the focus to GG on my computer monitor and was able to squeeze more sharpness out of it. The grain is still pretty decent considering the plastic fresnel screen but the fresnel lines are much more noticeable.
I'll try to get another clip on tonight.
Old March 16th, 2005, 02:32 PM   #6
I'd say you're definitely not completely focused on your focus screen, and hence its softness. Upping the contrast in post could help with the colors, but probably best to improve the design to get better colors without post. It looks like light leaking in, making it looked washed out. Hard to tell. Post pics and documentation of how you have constructed your device.
Steev Dinkins is offline   Reply With Quote
Old March 16th, 2005, 07:38 PM   #7
Here's a sharper clip. Didn't have time to set up the tripod so excuse the shakes.
http://rapidshare.de/files/897101/DOF3.wmv.html
http://users.adelphia.net/~jp1/dof3.jpg
Here's a pic of the adapter.
Old March 16th, 2005, 09:09 PM   #8
There ya go. Quite usable for a lot of different projects. All that's required now is good concept, lighting, shots, actors, editing, etc. Definitely great for proof of concept/ability stuff :)
Old March 17th, 2005, 12:17 AM   #9
Yes, the 2nd clip is much better. Looks good.
Kyle Edwards is offline   Reply With Quote
Old March 17th, 2005, 08:08 AM   #10
Rokta Bija,
Do you have a detailed picture of the setup of you static adapter?
Leo Mandy is offline   Reply With Quote
Old March 17th, 2005, 10:30 AM   #11
Looks great! Congrats.
Old March 17th, 2005, 06:29 PM   #12
Here's a breakdown of it so far.
http://www.fortvir.net/albums/album1...35_adapter.jpg
I will probably replace the m42 extension tube with 55mm spacers and then move the m42-55mm adapter next to the Pentax lens. I will replace the close-up filters with a single +7 or I might try a +10 and then shorten or eliminate the 55mm tube if I can.
Old March 17th, 2005, 07:22 PM   #13
Where did you get the plastic fresnel focusing screen? That setup looks great!
Old March 18th, 2005, 03:34 AM   #14
I bought everything on ebay, except for the m42-55mm adapter which I got from Joshua Provost.
Old March 18th, 2005, 08:12 AM   #15
If I am to understand everything correctly, the focal range from the GG to the lens has worked out perfectly with one of the extenders?
