Resolution Loss at DVinfo.net
Alternative Imaging Methods
Old March 14th, 2005, 03:36 PM   #1
Resolution Loss
does the Micro35 lose detail in the image?
i heard it may be the equivalent of over 200 hundred lines.
is this true?
anyone tested it?
Frank Vrionis is offline   Reply With Quote
Old March 14th, 2005, 03:43 PM   #2
Micro35
My last test showed a resolution of ~640 lines using a LOMO lens.
Hope this helps!
James
www.micro35.com
James Hurd is offline   Reply With Quote
Old March 14th, 2005, 03:47 PM   #3
LOMO lens? i'm getting a head ache already.
living in Australia i have many hurdles to overcome to get those things. plus the ignorance factor is giving me anxiety.
i bought myself some canon FD lenses. are these alright?
Old March 14th, 2005, 03:53 PM   #4
Micro35
The Canon FD lenses will work just fine.
Old March 14th, 2005, 07:45 PM   #5
640 in the horizontal direction I presume? What about the vertical?
Aaron Shaw is offline   Reply With Quote
Old March 16th, 2005, 09:03 PM   #6
Micro35
Aaron,
Sorry about the delay in responding. I'm prepping for one last trip...
It looks like the vertical was around 600.
james
www.micro35.com
Old March 16th, 2005, 09:13 PM   #7
i thought PAL was 720x576
and
NTSC was 720x480
which one is the 600 and which is 640??
Old March 16th, 2005, 11:14 PM   #8
I can attest to the sharpness of the FD lenses, they work really well with the setup. We used all primes and I recommend you do the same.
(r)yan
Ryan Hamblin is offline   Reply With Quote
Old March 17th, 2005, 10:07 AM   #9
Hi Ryan,
Is that canon fd MF lenses? I'm looking around for those, since they are cheaper than nikon MF's (one of the few advantages of incompatibilty!), and I heard the best in the canon fd line are equal to the best in the nikon MF line. Also, they have some lenses that are faster than nikon's in certain focal lengths.
What was your experience with them? Did you use an follow focus with them?
Steven
Steven Fokkinga is offline   Reply With Quote
Old March 17th, 2005, 07:51 PM   #10
The FD lenses work really well with the system.
Old March 19th, 2005, 06:27 AM   #11
RED Code Chef
Frank: I believe they are talking about how many lines they can
read of a test chart. The digital resolution will always be the same.
Rob Lohman, visuar@iname.com
Old March 19th, 2005, 06:38 PM   #12
Thanks Rob,
I’m aware of that. That’s why I said "equivalent".
Thing is James said 640 lines then said 600 lines.
I’m not sure what specifically he means by that.
PAL is 720x576 and NTSC is 720x480.
Obviously the resolution loss would most likely be from the 720 (horizontal?) and what about the 576 and 480??
Old March 19th, 2005, 08:09 PM   #13
The DV/DVCAM format could deliver only 500 lines of resolution.
Maheel Perera is offline   Reply With Quote
Old March 20th, 2005, 06:02 PM   #14
Maheel, I’ve no idea what that means. I’m a novice and need training wheels. Humour me.
Old March 21st, 2005, 09:15 AM   #15
Frank,
Although PAL frame is regarded as 720X576 the horizontal resolution is limited by the format. VHS can resolve only 250 lines. and S Video resolves 400. For DV/DVCAM it is 500.
