Micro35 (original thread) - Page 14 at DVinfo.net
Alternative Imaging Methods
Old February 7th, 2005, 06:50 PM   #196
Can someone post a link to a good resolution chart to shoot?
preferably one with resolution targets or stripes.
thanks!
-Les
Les Dit is offline   Reply With Quote
Old February 8th, 2005, 11:37 AM   #197
Les, try this:
http://www.bealecorner.com/trv900/respat/#EIA1956
Joshua Provost is offline   Reply With Quote
Old February 8th, 2005, 12:27 PM   #198
if we purchase the guide, will we have access to buy pre fabbed parts from you without buying one of the kits? like buying the macro, GG, rail mount etc.. i noticed the rail mount looks machined, and some of us wont be able to get that quality look without a mill.
Wing Gee is offline   Reply With Quote
Old February 8th, 2005, 12:36 PM   #199
Micro35
Wing,
Yes. You'll have access to those parts.
By the way, no machining has been done. Not even on the rails.
Got stickers coming!
James Hurd is offline   Reply With Quote
Old February 8th, 2005, 12:55 PM   #200
<<<-- Originally posted by Joshua Provost : Les, try this:
http://www.bealecorner.com/trv900/respat/#EIA1956 -->>>
Those look useful. Is there a link to the res target James used, to keep things consistent ? We should have a common test target I would think. One with resolution patterns.
-Les
Old February 8th, 2005, 09:38 PM   #201
Micro35
Here's a link to the one I used:
www.micro35.com/reschart.pdf
I dig Jushua's chart, I just don't have to to re-shoot them.
I've noticed that the Vegas program really compresses the video caps. Oh well.
Old February 8th, 2005, 09:59 PM   #202
Vegas outputs uncompressed PNG from the timeline if you set the Preview to "Best(Full)" and save as PNG. You shouldn't see any compression under those conditions.
Jim Lafferty is offline   Reply With Quote
Old February 8th, 2005, 10:03 PM   #203
Micro35
Hey Jim,
I did that but I still see a pretty big difference in the footage as its being played from the camera (during the video capture) from the still .png cap. Jagged edges etc...
Old February 9th, 2005, 12:44 AM   #204
Hmmm, could it be a motion sampling issue? In other words -- the look of footage always strikes me as better than still grabs because of the interframe motion, especially where interlace artifacts are concerned (those jaggies...)
At any rate, I don't think Vegas is compressing the images -- have you gotten better results with the same footage in other NLE's?
- jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Old February 9th, 2005, 09:05 AM   #205
Micro35
Haven't tried. I'll try premiere next time.
Thanks Jim
Old February 9th, 2005, 09:19 AM   #206
You need to take a snapshot of a static image or use a real progresive camcorder to take full resolution snapshots. If you recorde interlace, then you need to deinterlace the snapshots to get rid of the jaggies. But you will also loose resolution, even with the best deinterlace algorithms available. You can set Vegas to deinterlace snapshots, or use some other application (like Photoshop) to deinterlace the interlaced snapshot! :)
Cosmin Rotaru
Cosmin Rotaru is offline   Reply With Quote
Old February 9th, 2005, 09:23 AM   #207
Micro35
I'm shooting progressive. (DVX100A)
Old February 9th, 2005, 09:51 AM   #208
A! Don't mind me, then. I thought you shot interlaced... You should get perfect snapshots from progresive material. I don't get it. Vegas project is set to progresive and all? I don't think it matters, anyway...
Cosmin Rotaru
Old February 9th, 2005, 10:26 AM   #209
I believe even when using progressive, the footage will still conjure up interlacing problems. You have to de-interlace the footage afterwards.
Leo Mandy is offline   Reply With Quote
Old February 9th, 2005, 12:00 PM   #210
James are you recording in 24p? If so you could be encountering normal interlace from the pulldown.
There should be no need to deinterlace at all.
Aaron Shaw is offline   Reply
