#46 |
I find Aftereffects most convenient for jobs like this, because you have to create a project like Bob suggested only once. With every new clip, you just replace the incoming file and you're done. Aftereffects also supports realtime preview (given your system can handle it).
The 'layer stacking' Bob describes seems to be the same as native 'echo' function in aftereffects. I've used it to clean up nighttime footage in music videos I've done. Chris |
#47 |
<<<-- Originally posted by Chris Rubin : I find Aftereffects most convenient for jobs like this, because you have to create a project like Bob suggested only once. With every new clip, you just replace the incoming file and you're done. Aftereffects also supports realtime preview (given your system can handle it).
The 'layer stacking' Bob describes seems to be the same as native 'echo' function in aftereffects. I've used it to clean up nighttime footage in music videos I've done. Chris -->>> You should be able to just replace media in Vegas, too. Ditto the realtime preview. - jim |
#48 |
static adapter
hi everyone I sent a email to cris hurd with a photo of the static adapter .I will be linking to it soon
#49 |
I've been trying to replicate Chris's results using Vegas with mixed progress.
In Vegas, I'm running the inverted grain image along a track, and parenting it to a copy of the footage I'm degraining. Then, I set the grain track to luma mask, and on the copy of the footage (the composite child), I'm adjusting luma up, to bring the darker grain of the image within the range of the brighter grain of the original footage. All of this is placed over the original footage, left untouched. I will say it *supresses* the grain, but does not remove it entirely -- it looks good for stills, but in motion it doesn't add up to a 100% grainless image, and in reality there's little aesthetic difference between one kind of grain and the other. I tried the AE 6.5 demo today, just to see if AE would treat the image differently than Vegas using Chris's technique -- the results aren't as good as I got with Vegas, but I'm left with the impression that with a little tweaking, I could get them close to one another. Still, it's not a completely grainless image. I'd like to be proven wrong -- Chris, if you've got some footage to show at full DV res, I'd be happy to host it for a bit. I'd really like to see the results in motion... - jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G |
#50 |
just wandering - did anyone tryed to subtract grain with "digital fusion" (probably now "maya fusion")?
some time ago i saw brilliant results with that software, but i never use it. maybe someone has expirience with it? filip |
#51 |
I'm not sure of this but you could try using After Effect's (6.5 pro) degrainer to do this task. I know you have to sample the footage first - perhaps you could use the grain image as this sample? I think AE will literally perform a subtraction (not just a manipulation of overlay settings).
#52 |
grain
#53 |
Richard,
I have seen footage that was treated with Grain Surgery and the results were stunning. On another note I was talking to a friend who is involved in sandblasting and he says he can get a finish down to 3 microns so I was wondering what would be the ideal finish for frosting glass in microns or grit rating? |
#54 |
I'm sorry, but grain surgery just doesn't do it. Just blurs your fine detail. If you want good results, the only decent noise reduction plug-in I'm aware of is NeatImage. But whatever you use, the video will still look 'doctored'.
Chris |
#55 |
Chris, I know for a fact that it does more than blur fine detail. You literally sample an area of the frame and the software attempts to intelligently remove the noise. Doesn't always work well of course but it can work amazingly well when done correctly.
#56 |
Chris,
Any chance we can see some footage using your method? I'm not getting stellar results and I'm worried it's just because I'm missing something... - jim |
#57 |
I'll post my tests as soon as I get my adapter assembed again (in a few weeks probably). I designed a new adapter with threaded tubes (enables me to adjust the gg distance from both the camera lens and the 35mm lens on the fly) and I'm waiting for the parts to be finished.
#58 |
static adapter
#59 |
Richard, when are you going to e-mail out some information on the finished adaptor you were talking about?
#60 |
35mm adapter parts list
hi everyone: this is a link to a new thread with complete parts list
and photo http://www.dvinfo.net/conf/showthrea...threadid=37296 |
