could this be an alternative to mini35? at DVinfo.net
Alternative Imaging Methods
Old December 14th, 2004, 10:38 AM   #1
i don't know much about photo lenses so this question may sound naive but check this out:
http://www.adorama.com/CAEFXLA.html?...20ef&item_no=1
peace
Yohann Kouam is offline   Reply With Quote
Old December 14th, 2004, 11:03 AM   #2
No, that multiplies the focal length of any of the lenses you use with it by 7.2x. That means if you want a standard 50mm lens (35mm equiv), you'd need about a 7mm lens, or a combo of lenses and wide angle adapters, and even then I doubt the results would be the same.
Given the same aperature, longer lenses have less depth of field, so even with the multiplication, I think you'd increase your depth of field when compared to the 35mm equiv.
http://www.IndieRentals.com
RED Rentals, Camera, Grip, Lighting, Sound, Post and More.
http://www.madmojo.com
Production blog.
Eric MacIver is offline   Reply
