#361 |
@ Kitaev
It is nice to see you here. I hope you can answers this main question about the sensor: - What is the optical dimension of the sensor. We all need the exact size in mm x mm. (Please not only the round 1" diagonal) - What is the exact size of one single pixel in ym - What is the max res. in pixel x pixels (the sensor, not the camera output) - Is it a 4:3 or a 16:9 Sensor - Is it possible to get out 12 Bit - What is the max. frame rate per second with max. sensor res. - What is the max. frame rate at 1920p, or 720p We understand your camera can run also at higer speed, but with lower res. - Use the sensor for high speed (and low res.) a smaller optical size (a little window, so the view of range is different) or use the sensor in all cases the max sensor size Last question: What do you mean with a optical converter ? Thanks |
#362 |
Is your chip APS sized? or smaller..you said 20% crop, is this with PHOTO lens or with 35mm cine lens? Photo 35mm is much larger then cine 35mm...
yes I would like to see a shot with a 50mm ..what type of lens mount do you have? can you use OLED for a viewfinder? how is the resolution on your current viewfinder...problem is when your outside in brihgt sunlight a LCD is usless..I hate to say it but it's true. I have shot like that and had WORTHLESS footage from not knowing what I am shooting due to the sunlight hitting the LCD. We NEED a viewfinder for a real product |
#363 | |
http://www.emagin.com/html/consumer_...ts_product.htm |
#364 |
I have seen that product, can you use it? its only $800, but it's 3d...how can your camera hook up?
also your images look nice, I see a really low quality bayer, are you using linbayer? what about static pixel noise? looks like you have some of that, can you filter it out?? |
#365 |
Hi all, Hi Alexander, glad to see you here and glad to see this questions I would never know to ask. :*)
Alexander, No problem with the delay, of course I don't need the camera that is not tested and is working properly, I'd rather wait. The only thing is that I realy have a need for the camera and sooner I have more cost effective it is for me. I also hope that me being so intended for your camera makes you also more up to finalize it sooner, and I am also a good feedback to make your product finer and hopefully comments of this great people in this forum will also help you. I honestly wish you success and there is a great market worldwide, for your product if you make it good. At least I know for sure that you will have about 5 of them potentially sold in Georgia, that is only companies I know of. But also there is a point of beeing late on the market, the first one to make a good camera will be successfull. I agree with Obin, viewfinder is an important factor and to tell you the truth I prefer to have a very similar to normal viewfinder. As with camera I would prefer it to be very like the film camera, same with the viewfinder, but this is not the crutial thou. "50mm lens shot of a person with a light on them..." is also very interesting. To sum all of this, I hope I will have the camera ASAP, I am ready to buy one or even two, shortly, and I don't know technical discussion of the chip and other things, I can tell how good it is in Real World, the bottom line is when I do the real shoot of the commercial and get the result, that will be the best way to evaluate it. |
#366 |
www.ctt.ru/files/demo/supermotion_rugby.rar
White color is clipping too much I think. But there are colors to the picture, that is good. And also it seems a bit out of focus. Well actually I think it might be what Alexander said about the focusing. Comments |
#367 |
found that maybe vented a zillion times but !!!!!!
http://www.illunis.com/
and there XMV2001 and XMV 2020 Specs at a Glance: Active Pixels: 1600 x 1200 Pixel Clock: 40 Mhz Pixel Size: 7.4um x 7.4um Sensor: KAI-2001, KAI-2020 Frame Rate: 33.6 Fps (Dual Tap) 18.3 Fps (Single Tap) Bit Depth: User selectable 8, 10 or 12 Dynamic Range: 55dB Power: 12VDC - 4.7Watts Interface: Camera Link Base Mode Dimensions: 37 x 57 x 57mm http://www.illunis.com/Files/XMV-2M.pdf well it is cameralink but there are boards like the expresso and so on not knowing what's wrong, maybe the price, it's Kodak CCD I do know the imager very well did know that's a lot of work to do they've done so what ? |
#368 |
Hi ALL,
first- about sensor, it has 4M, 16x12mm, 6,9pixel, 2400x1700 it’s CUSTOM sensor, real 10bit, max speed –1GB/sec- it’s about 350fps on HD resolution, or ~800 on SD it’s first use in space, but now we try to make cinecamera… (our next one will be with 12M resolution, 12-14 bits, but 2-3 years later…) about other sensors- we tested ALL of them- all have motion bugs on rolling shutter (if it has speed less then 120fps) or problems with noise or sensitive. About viewfinder- You are all right, small one is good too, but for use our 8” monitor- you also have some reasons- first- more detail on more size and more resolution-we have real 1024x768 monitor, on HD you may se ½ picture without any artifacts, as well , max resolution of 0.8” OLED display- 800x600 with resizing you will have a lot of bugs on screen, (we tested same device - http://www.i-glassesstore.com/) looks not good, but if you want- no problem: special order- 3 month. and if you want to work on sun- use http://www.hoodmanusa.com/H789.asp . about our bugs: we have real bug with “focus” – it’s not real focus problems- its bugs of linear demosaic-we use it for viewfinder on high speed – this project was for Super slow motion broadcast camera, and we tested it with SONY cameras –(that’s we have such colors) - now we testing new soft, and I think to show new pictures later this week. and last- we work on this project more than 6 years, this is 4’th generation of “low cost” camera. fist time we show our prototype on NAB2000 as HIMT inc USA, and of course, after 6 years I may say- this is NOT easy- we have a large team and work for 6 years- I may say – if You want to make you own camera- welcome, but you need large team, science support and a lot of investments, Best regards, Alexander Kitaev www.ctt.ru info@ctt.ru kit@1tv.ru |
#369 |
Slow Motion - Seeking your opinions
This is my new TV commercial for one of the construction companies in the city. Never mind what the idea is, it needs to be translated. Just look at the picture and slow motion effect.
I shot it with Photron camera, I meet with the company in Las Vegas. It records up to 4000fps. www.photron.com It is black and white and only yellow color is left on purpose. It needs some final color correction thou. It is compressed thou, later I will upload an uncompressed version. www.pepsi.ge/axis/axis.zip What do you think? |
#370 | |
Thanks Wayne. |
#371 | |
#372 |
Great work...what was your budget on that? looks really good....
#373 |
4000fps
It looks indeed very nice. I looked at their site a long time ago. But it was mostly low res stuff.
Is it a big setup? Is it flexible? Would you have the kindness to post a behind the scenes picture? |
#374 |
No, I rented it didn't buy. The total budget for the commercial was around 14000 USD. Well, in most scenes you see 1000fps or 2000fps, except for the first shot of the ball, it is 4000fps. It is not very flexible but you can do the job. Actually it is a camera head, connected to a box with all the processing power and the memory and 2 cables between is around 10meters long. Since you can not move the camera during the shot (pan, tilt or anything) it is flexible, because you only need to setup the shot and then not touch the camera. When I say you can not move it, I mean you can but if you do, even a very smooth movement (if it is not a motion controled) will look very unsmooth when played in slow motion. So basicly if you consider this fact, it is very flexible.
The camera is Ultima APX and the guy I rented it from said that this one is much better than newer versions of APX, like APX-RS. Right now I am away, when I am back I will post the behind the scene pictures. That will be in 10 days. |
#375 |
Congrats Levan! Any up-date of your ctt.ru camera experience?
