Canon XL-1 Relaylens (original, now merged w/ consolidated XL1 thread) - Page 8 at DVinfo.net
Alternative Imaging Methods
Old October 15th, 2004, 06:15 AM   #106
I was wondering about the whole prism (rotate image) question. Doesn't the prism and mirror steal F-stops??
Because on the XL-1 you can simply flip the eyepiece to the other side and the image is corrected. Then in post you can just use the:
http://www.leadtools.com/SDK/Multimedia/Direct-Show-Filters/Multimedia-DirectShow-Rotate.htm
during capture (without loss I hope). If this is true then I would rather avoid bothering with prism and mirrors.
Or am I wrong???
Anders Floe is offline   Reply With Quote
Old October 15th, 2004, 07:21 AM   #107
We can sell the relay lens for Euro 900,- (round $ 1.115,-)
We found a cheaper one, but i dont know how good it is. We check it next 2 weeks
A mount adapter (to connect the lens to the Canon) cost Euro 198,- ( $ 245,- )
BTW: only with this lens (without the other GG adapter parts) you can make good night shoots. ( F stop = 0,95 )
Anders,
yes, the prism "steal" a little bit light but. In F-stops? I think only 0,05.
The prism is a expensive part, because you need a "big on" with inside more than 40mm diameter and it must be color corrected. I will check out the best price till next week Without the prism you need 10cm more distance.
Rai Orz is offline   Reply With Quote
Old October 15th, 2004, 07:54 AM   #108
I don't understand why it needs to have 10 cm more distance!
In a normal still-camera the lens is only about 5 cm from the film... I can see that without the prism and mirror the light will travel a shorter distance but... I'm sure that you are correct but could you explain it to me?
I would properly be interested in buying a colorcorrected prism then - So it would really like to know the best price you find.
In the PDF file showing the PRO35 there is something called "Schutz glas" - Is that a fresnel??
Old October 15th, 2004, 08:13 AM   #109
schutzglas means protective glas
Christoph Hopf is offline   Reply With Quote
Old October 15th, 2004, 08:13 AM   #110
The way through a prism is longer than the prism outside. A still-camera have also build in a prism. So the way in a still-camera is also more then the outside dimensions.
But in different to the still-camera prism, you need a bigger one, because the relay lens have more than 30mm light circle. Thats why you need the big prism and thats why it take more distance.
Okay, you can mount a macro lens in front of the relaylens to reduce the distance, but than you will have some distortions.
The "SCHUTZ GLAS(S)" is only a clear glass to protect (SCHUTZ=protection) the inside parts for dust and dirt.
To reduce (elimate) the hot spot there is a convex lens with the plan side very near behind the vibration GG (sorry last day i call this condenser, thats wrong)
Old October 15th, 2004, 10:45 AM   #111
You say that the prism is expensive - what are talking here, $100 ? $500??????
Old October 18th, 2004, 09:01 AM   #112
Per member's requests, this thread has been merged with the Consolidated XL1 35mm Adapter thread -- this original copy is left intact for your viewing pleasure, but please direct all replies to the new monster we've created using the link above. Thanks,
Chris Hurd is offline   Reply
