Microcrystalline Wax Techniques? - Page 33 at DVinfo.net
Alternative Imaging Methods
Old September 15th, 2005, 01:19 PM   #481
Curious: how have you been getting H.264 encodes done? I've worked with X264 in VirtualDub, because it doesn't work in Vegas yet (nor does QT 7). It's OK but the render times are a pain.
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Jim Lafferty is offline   Reply With Quote
Old September 15th, 2005, 01:20 PM   #482
Glen: I've gotten some acceptable results with microwax (I still think it is the best static solution available), but given the difficulties (not being able to duplicate good results) and uncertainties (Will the wax pull from the glass later? Will it melt? ... ) I have moved back to regular ground glass, but I'm putting a new spin on it. << Pun intended. >>
Jim: Thanks for the compliments there! Also, thanks for linking my images/clips from your site! I've gotten quite a few hits from there!
Frank Ladner is offline   Reply With Quote
Old September 15th, 2005, 01:22 PM   #483
Cool -- glad it hasn't created problems for you :D
Old September 15th, 2005, 05:56 PM   #484
Jim wrote:"Frankly, the 1.4 micron alumina GG I have was such a comparitvely easy job to produce (and reproduce consistently), that I've been half tempted to get 1 micron slurry and see if I can call it a day."
How well does it diffuse light? Does it diffuse completely? Does anyone else see a difference between the glass diffusers and the wax ones -- especially in shadow detail? Which brings up an earlier post you made. Have you had any success with scanning or shooting your various ground glasses? I'm sure it's a lot of work, but I think everyone would find it quite educational, if you can find the time.
As for H.264 encoder, I'm just using what comes native in Quicktime 7. Maybe on the PC you have to get a software update? The render times are slow, but I can get full resolution video at 600kbs and not be distracted by the compression artifacting typical of the other codecs. In fact, I'm finding with CG stuff the final image is indistinguishable at that data rate. If you download my last clip, and play it full-frame, you'll see more flaws in the wax than codec noise, and some of that is simply from originating as DV.
Frank, your concerns about wax are true enough. I've spent more time preparing and planning than actually doing, but am still hoping that I can come up with a cookie-cutter technique. Oscar seems to have an easy time with it -- if only I could find what brand of Tobacco can (or whatever that is) that he's using :)
Is anyone here associated with the G35? Their footage looks incredible (please excuse me if that's a really dumb question).
Like Jim, I'm inspired by everyone else's success.
G
Glen Hurd is offline   Reply With Quote
Old September 15th, 2005, 06:31 PM   #485
Jonathan Houser, I think, is the main person behind the G35 and he is on these boards occasionally, but he won't tell you anything about the device.
And about what Frank wrote,.. I wouldn't be very concerned about how the wax will hold (Will the wax pull from the glass later? Will it melt? ... ) because I've put my wax glasses through such terrible circumstances (heat, transportation and I dropped them on the floor quite a few times) and nothing happened, so..
Oscar Spierenburg is offline   Reply With Quote
Old September 15th, 2005, 06:51 PM   #486
Yeah, Frank! How many do you need to make, anyway? ;) LOL
Old September 16th, 2005, 06:22 AM   #487
Ha ha!
Well, if I had a tobacco can like Oscar's maybe it would boost my morale. ;-)
But seriously, I did try a thoroughly-cleaned tuna-fish can but the inside layer, after heat was applied, started to melt/burn away, leaving debris in the melted wax. What are you other guys using for this?
Old September 16th, 2005, 07:14 AM   #488
For the debris I've used "cold-weld," dust, hair, burnt wax :)
For containers, my most recent is small aluminum pie plates. I simply shred the plate away from the wax, so I can then break, cut, peel it away from the glass.
G
Old September 16th, 2005, 07:18 AM   #489
Glen: I've done something similar by forming aluminum cups. (When using the original vertical / capillary method.)
But you are right - you can just peel the foil away and it is much easier.
One really neat thing about the 'flat' method (cigar case) is that you use WAY less wax. (So you don't have to worry about using a 1/2 LB batch of it just to submerge the glass - and then get the wax dirty.)
Old September 16th, 2005, 07:33 AM   #490
I can't follow that...you mean the whole can melted?
I put the tobacco can (which smokes better than fish anyway) on a thick saucepan on a low flame (on the stove)
Old September 16th, 2005, 07:37 AM   #491
Oscar: The inside wall started to peel from the heat.
Maybe I need an interface (ie. saucepan) between the can and electric hot-plate to help with heat distribution.
Old September 16th, 2005, 08:00 AM   #492
Yes. Also better to even out the warmth on those hot plates. I would suggest a saucepan.
Old September 16th, 2005, 08:24 AM   #493
I suspect the inside of the tuna can had a thin plastic layer to protect the fish from getting a metalic taste over time, and it was that plastic layer that melted. If you go with cheap sardines, however, you don't get the plastic finish on the inside, because people who eat cheap sardines aren't as picky about taste -- the metal tastes fine!
So go sardines, Frank. The cheaper the better. Preferrably packed in some distant far-off country. You don't need to be so upscale when melting wax LOL.
However, getting the glass out seems to be a challenge. I use a grapefruit cutting knife -- designed to cut and scoop grapefruit slices. Still a pain . . .
Old September 16th, 2005, 08:29 AM   #494
HA HA HA!
Thanks, Glen! That makes sense about the can having an inner coating.
The next try will be with a sardine can, then. (A thoroughly-cleaned one.)
Old September 16th, 2005, 08:46 AM   #495
Waddya mean the cameraman smells? . . . like sardines? No! Really?!!
<sniff>
Um, Frank? Uh, Fra-a-a-ank?
What's that smell?
. . . Your lens! . . .oh, your lens-adaptor! Sure.
OK, Frank. Thank you very much. And . . . and don't call us -- we'll call you!
