uk ground glass at DVinfo.net
Alternative Imaging Methods
Old September 17th, 2004, 04:22 PM   #1
uk ground glass
hi
where can i find a uk supplier for some really high quality ground glass. or just any normal ground glass, not the frosted cd.
thanks
Rabi Syid is offline   Reply With Quote
Old September 17th, 2004, 05:21 PM   #2
You're best bet is to look for a supplier of WAO5/1500 grit aluminum oxide, or smaller grit if it exists (WAO3?) and make your GG yourself.
- jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Jim Lafferty is offline   Reply With Quote
Old September 18th, 2004, 05:13 AM   #3
ok thanks, but what is that? is that the gg?or how would i make it from that?
Old September 18th, 2004, 07:41 AM   #4
ground glass
hi everyone A few month,s ago I finished a static adapter .I tried many types of ground glass : homemade , with every type of grit, acid etching. the best glass to date was purchased fom a optical company for $22, the company was optmo sigma, and the glass was 1500 grit 50mm I think someone had a source in england
http://www.knightoptical.co.uk/acatalog/DiffusersGroundGlassDiffuserGround-LEGB.htm I don't know if this is the same as optmo sigma http://www.optosigma.com/miva/merchant.mv?Screen=PROD&Store_Code=OS&Product_Code=pg211&Category_Code=Filters+%26+Apertures
Richard Mellor is offline   Reply With Quote
Old September 19th, 2004, 10:50 AM   #5
can some1 clear this up 4 me. can i make a moving (augs35) GG type device for xl1 or 2 or does it have to me static?
thank you
