is this $1,545.00 Sony camera HD capable? XCDX710CR at DVinfo.net
Alternative Imaging Methods
Old September 7th, 2004, 06:11 PM   #1
I was dorking around on Sonys industrial website, I came across this promising cam. Sure it needs Glass but this cam looks like a 30p HD 8-10bit uncompressed(?) output to firewire cam!!!! and for a retail price of $1,545.00...oh yea you might be able to get some serious DOF without the need for an agus35. Just slap a 35mm c-mount on there. Am I dreaming?
sony link
http://bssc.sel.sony.com/Professiona...20054&id=73500
retail link
http://www.goelectronic.com/Merchant...DUSTRIAL+VIDEO
Sony's new XCD-X710CR progressive scan, IEEE 1394 camera is the latest addition to join Sony's growing line up of digital, high-speed cameras. This new digital camera satisfies the demand for high speed, color, progressive scan cameras and are ideally suited for those customers who need (a) a progressive scan camera that can achieve 30 frames/sec in color; (b) high resolution of 1024 x 768 in an industrial housing; and, (c) access to the raw pixel values so customers can do their own color processing. The "CR" in its model number stands for "Color Raw". This new "CR" model uses a CCD with a color mask (commonly called a "Bayer filter") and output the "raw color" pixel values in 8 or 10 bit to be converted to a color image on the computer. The color conversion that takes place in the computer is supported by Sony's new IEEE 1394 software and most 3rd party Firewire® compatible software (e.g., Matrox, National Instruments and Unibrain).
High frame rate and high rate scanning
Separate gain for red, green and blue pixels to maximize the color S/N ratio
Color conversion process handled by a computer (not by the camera)
Multiple Cameras can be synchronized at full frame rate with trigger and will self-synchronize to the common Firewire compatible bus clock
Fast software trigger
Allows for multiple cameras on a single bus in 8-bit mode (less bandwidth per camera)
Binning 1 x 2 and 2 x 2 for high frame rates and high sensitivity in monochrome
High shock and vibration resistance
Feature
Benefit
High Frame Rate & High Rate Scanning
30 frames/second at up to 1024 x 768 in 8-bit mode
Raw Pixel Values
The XCD-X710CR camera outputs the raw pixel values as Mono-8 (8-bits per pixel) in 8-bit mode or Mono-16 (16 bits per pixel) in 10-bit mode. The low level driver or your application can then convert the raw image to color using common Bayer conversion routines.
Color Processing Outside the Camera
In some instances it is preferable that the color processing occur outside the camera. By doing so, this enables special processing to the image prior to color conversion and gives you the ability to use your specialized color conversion routines. The XCD-X710CR camera digitizes only the full lines of a partial scan area so the frame rate can increase in partial scan mode.
Specification
Detail
Image Device
1/3 type Progressive Scan CCD
Picture Elements
1034 (H) x 779 (V)
Image Size
XGA: 1024 (H) x 768 (V)
Lens Mount
C Mount
Minimum Illumination
4 lx (F0.95 lens open, +18 dB Gain)
Digital Interface
IEEE 1394-1995
Transfer Rate
400/200 Mbps
Frame Rate
30 / 15 / 7.5 / 3.75 / 1.875 fps
Gain Control
Auto/Manual (0 to 18 dB, 0.035 dB steps)
External Shutter
1/100,000 to 17.5 s
External Trigger Shutter
Trigger start (mode 0), trigger start and exposure duration (mode 1)
Partial Scan
256 zones (16 x 16)
Power Requirements
DC 8 to 30 V (from IEEE 1394 camera cable)
Power Consumption
4.5W
Dimensions
44 (W) x 33 (H) x 116 (D)mm / 1-3/4 x 1-15/16 x 4-5/8 inches)/16 x 4-5/8 inches)
The glory of the World passes by.
John Gaspain is offline   Reply With Quote
Old September 8th, 2004, 10:43 AM   #2
Contributor
Awesome, but custom software must be written. Also, it seems to be 1/3" , where will you get that extra differential focus from? It is still a small sensor or did I misread?
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old September 8th, 2004, 12:31 PM   #3
it comes with the software!
Old September 8th, 2004, 05:13 PM   #4
Well the bad news:
- Imager size: only 1/3 inch. If you want to use 35 mm optics you have to multiply the focal lenght by about 7. a 28mm becomes a 196mm tele
- Resolution: 800.000 pixels with bayer filter arrey. This isn't even 1mpix.
- The sensitivity: The color model has a minimum illumination of 20 lux at MAX. gain (+18 db)
- The bitdepth: Only 8-bits available at 1024x768 - 30 fps.
Anders Holck Petersen is offline   Reply
