Way to losslessly rotate DV files? at DVinfo.net
Alternative Imaging Methods
Old August 9th, 2004, 05:13 PM   #1
What's the best way to rotate the files captured using a mini35 adaptor without recompressing?
-Brandon
Brandon Adams is offline   Reply With Quote
Old August 9th, 2004, 07:26 PM   #2
Rotate
Here is a very interesting software for that rotate the image at the capture .
http://www.leadtools.com/SDK/Multime...how-Rotate.htm
There is a demo available for download
Alain
http://www.kheops-tech.com/~ad3d/
Alain Dumais is offline   Reply With Quote
Old August 10th, 2004, 01:59 AM   #3
I downloaded LEADTOOLS Multimedia EVAL 14.0 but I don't understand how to use the rotation filter... a little help? Thanks for the link btw
-Brandon
Old August 10th, 2004, 02:35 AM   #4
RED Code Chef
With JPEG it is possible, so in theory it should work with DV as
well. I highly doubt there is anything on the market that would
allow for this, though. If you wanted to make such a function
you would basically have to write your own DV codec.
Rob Lohman, visuar@iname.com
Old August 10th, 2004, 03:07 AM   #5
If you are mainly concerned with editing, I'd say just flip the image and never resave it with DV codec , just work with it.
What's the final output? DVD? FILM ?
-Les
Les Dit is offline   Reply With Quote
Old August 12th, 2004, 03:16 PM   #6
<<<-- Originally posted by Les Dit : If you are mainly concerned with editing, I'd say just flip the image and never resave it with DV codec , just work with it.
-Les -->>>
That's exactly what I do, and it works fine.
Or you require a separate 'flipped' copy for some reason, and you have a lot of hard drive space, just render to an uncompressed AVI.
Frank Ladner is offline   Reply
