Achieving The Look With The Mini35 at DVinfo.net
Alternative Imaging Methods
Old August 2nd, 2004, 10:44 PM   #1
I've been doing some outside test shooting with my mini35, the DOF is great but my images don't have that grainy look. The footage looks too clean. This is my setup: Series 3, Xl-1, EF 85mm 1.8, gain -3, shutter 1/60 and in frame mode. Any suggestions would be greatly appreciated.
Gerald Baillgergeau is offline   Reply With Quote
Old August 3rd, 2004, 12:16 AM   #2
Hmmmm...well, the Mini35 isn't really supposed to make the image look grainy. You might want to try shooting with a higher gain setting, or adding grain in post.
Charles Papert
www.charlespapert.com
Old August 3rd, 2004, 02:26 AM   #3
I guess grainy was the worng desciption, Ill have to fiddle aroound with some post filters and color correct the footage. MB just gives render time a meaning...ssssllllooowww.
Old August 4th, 2004, 02:10 AM   #4
If you really want "grainy" recordings, you can also try stopping down a few stops to restrict the light coming in your lens (don't stop down the camera), that may help.
http://www.IndieRentals.com
RED Rentals, Camera, Grip, Lighting, Sound, Post and More.
http://www.madmojo.com
Production blog.
Eric MacIver is offline   Reply With Quote
Old August 4th, 2004, 02:21 AM   #5
With the EF lenses I won't be able to step down any more then the wide open setting.
Old August 4th, 2004, 03:07 AM   #6
Could you chuck a filter on the front somehow. Pantyhose? ;)
Aaron
My Website
Meat Free Media
Aaron Koolen is offline   Reply With Quote
Old August 4th, 2004, 09:00 AM   #7
add a ND8 to your objective lens and run the mini at slow speeds that should give you a grainy look
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old August 4th, 2004, 09:35 AM   #8
With the 3rd generation Mini35, making the groundglass visible by stopping down will result in the "spinning vortex of hell" effect, which is a whole other animal.
Gerald, by "stopping down" Eric was suggesting to close the aperture, not open it further. You can then compensate by opening the aperture on the relay (lower numbers) to regain proper exposure.
Charles Papert
Old August 4th, 2004, 11:30 AM   #9
Charles, the canon EF lenses don't have manual controls. So my 85mm 1.8 is always open @ 1.8.. When I need to, I use the relay to step down.
Old August 4th, 2004, 11:40 AM   #10
In that case, your best bet would just be to do it in post. There's plenty of software/filters with a variety of editing packages that can help add grain...
Production blog.
Old August 4th, 2004, 01:35 PM   #11
My fault fellas, my desciption of the look I'm talking about is more like a blurry motion in the footage. The images have a bit of a slur to them....Question? When dv film like "Open Water" or "28 Days Later" is put to dvd, is the 35mm print used for the authoring?
Old August 4th, 2004, 01:40 PM   #12
Usually if they go to 35mm from MiniDV, then they make a DVD, they do digitize the 35mm print. Now, for the blur, you're going to just want to get a 24p camera and/or use Frame Mode on the XL1 and use a shutter speed like 1/24 (if 24p) or 1/30 (if 30p/frame mode)
Production blog.
