Home Made HD Cinema Cameras - Technical Discussion - Page 25 at DVinfo.net
Alternative Imaging Methods
Old April 14th, 2005, 12:58 AM   #361
did some reading here. Looking for good sensor choice to use in HomeMade HD. I have found, that the only one 2/3 that do electronic snapshot is the ibis5a. Am i wrong here?
And and what do you feel about using rolling shutter sensors with mechanical shutter like http://sunex.com/News/Press8.htm or even homemade rotating shatter?
Konstantin Serafimov is offline   Reply With Quote
Old April 14th, 2005, 09:48 AM   #362
Yes, for cmos that we consider Ibis5 is the one for snapshot shutter (but lupa series, fast motion micron, and any other expensive ones have snaphot too).
For mechanical shutter, I think noise and reliability VS cost issues (I think you will have to buy an expensive one to get reliability, not best to be homemade). But I see reference to rotating mirror shutter. I have not seen these, but hopefully simpler, more reliable and able to be made at home. But I am sure others here will have better opinion than mine.
Thanks for coming Konstantin
Wayne.
Wayne Morellini is offline   Reply With Quote
Old April 14th, 2005, 04:16 PM   #363
Silicon Imaging, Inc.
Konstantin,
Watch whether the sensor can overlap the exposure and readout times. With the IBIS-5A, they are sequential. If the max readout time is 1/40 sec (25msec) and you want a frame rate - integration + readout of 1/24 sec (41.7msec) then your max integration time is 16.7msec. Since the sensor isn't too light sensitive, you might have low light problems
This is not the case with some of the other sensors Wayne talks about.
Steve
We see the Light!
http://www.siliconimaging.com
Steve Nordhauser is offline   Reply With Quote
Old April 15th, 2005, 06:11 PM   #364
well, i've got more stupid questions:
Steve: 60 fps chip has lower readout than 40 fps but, how to calculate from sensor data, what readout time is?
I'm curious how white balance is achieved in single chippers. Lets say we cant exposure r-g-b pixels separately isnt it? Rai wrote they doing wb in two steps: first in-chip, second while 10->8bit conversion. mean its more range of 12 bit adc converts into better wb capabilities. right?
and, sensors, i tryed to contact sensor manufactures to get eval kits, ie sensor + board + drivers + docs. At least FF and Altasens offer- still no reply. How do you "testing" this or that sensor, how to get em? Thought i'm a private developer and would not buy more than 1 unit anyway. May be there is some global sensor supersore :)), like bhphoto for video gear?
By the way, i'am not an electronics specialist, more a C programmer with video as parttime biz/hobby. So I like idea of Rai that we can take sensor board, put it into linux mc then write to hdd. I also like to spent some freetime to learn how to make these things to work. But if sensor kits are so rear beasts (oem only?) it may be practical to go with camerahead.
Old April 16th, 2005, 05:44 AM   #365
I suggest you get (and everybody else) the documentary DVD "The Corporation". Watch through the film, then watch through the special features, then watch through the second disc interviews (around 7 hours worth all told). You will be progressively more shocked by each of these. This bias and collusion that keeps small people (low profit customers) out of large business is common. You are much more likely to get somewhere if you have big money, or established company that can order big. The market is getting more and more sown up for big players.
What people here do is get cameras/sensor boards from various camera companies to test the sensors. Steve is from Silicon Image, there is Sumix (one of the cheapest), and a bunch of others.
Be careful with Ibis5a, there is various ways to implement it. The SI version appears much better than the Sumix version that Ben had last year, and Rai's implementation is better again. You might find this with other sensors.
Everybody is on the Micron, Ibis, Altasens bandwagon (no 3chip yet) so it might be good to find an new alternative sensor that is cheaper/better rather follow what other's are doing.
Wayne.
Old April 19th, 2005, 09:40 AM   #366
Here is some interesting tech:
This is the 300GB optical holographic disc due next year:
http://www.extremetech.com/article2/...129TX1K0000532
The future is here, but only at 20MB/s so far. At least it is cheap for backup storage or RAW footage. Notice that it uses a camera chip from FillFactory as it's sensor ;)
This is the competitor:
http://www.extremetech.com/article2/...099TX1K0100486
New HD Mac's:
http://www.betanews.com/article/New_...ase/1113497814
Old April 20th, 2005, 04:54 AM   #367
Nab reports: The New Apple stuff:
http://www.tomshardware.com/business...418/index.html
The new Panasonic (note: they are talking about 1440*720p mode, I think I have heard of such a thing, but not on this camera?):
http://www.tomshardware.com/business...191/index.html
Old April 20th, 2005, 08:53 AM   #368
Konstantin,
The min readout time is:
(horiz size + horiz blanking) * (vert size + vert blanking) * pixel clock
On many sensors, you can increase the vertical blanking time to keep the readout time fast but the frame time slower (what you want for rolling shutter artifact reduction). On others, you just drop every other frame.
On single chip cameras, some have separate analog gains for each of the 4 (R,G1, B, G2) color channels. These are only rough gains to keep the dynamic range. You will still need to do a color matrix to get accurate white balance after capture.
Sensor companies do not want to support single unit sales. It costs the same to support a single unit sale as an OEM design-in that yields high volume. That is why we will sell board sets to integrators - the volumes can be low but that is OK. Some companies will only do business in the 10K units per year volumes. Our volumes aren't that high but we do have some large commitments to the sensor manufacturers.
We see the Light!
Old April 20th, 2005, 08:53 AM   #369
The Tom's Hardware info on the Panasonic is very inaccurate. I like Tom's Hardware but I wouldn't trust anything in that specific article.
Aaron Shaw is offline   Reply With Quote
Old April 22nd, 2005, 05:27 AM   #370
Yes, I know what you mean, but even Tom's is reporting on HD camera stuff now, which is good news for Rob's $100 software (when it gets finished).
Old April 22nd, 2005, 05:33 AM   #371
Which software are you talking about?
Michael Maier is offline   Reply With Quote
Old April 22nd, 2005, 07:03 AM   #372
Rob Scott's capture software for the SI cameras, he was the original one to volunteer to do software. He has been busy for a while. The link to his Wiki is in my first post in this thread.
Wayne.
Old April 22nd, 2005, 01:14 PM   #373
its me Konstantin Serafimov, must be smth wrong with this forum, my old password is not valid anymore, and so does my real name and email :)
thank you Steve, very informative. So i havent got it, is SiliconImage a wholesaler or retailer? Should i consider this respectable company as a potential seller of camera for me?
As far as I still have got no hardware, i'll continue theoretical talk. How image from cmos sensor could compared to ccd one. I remmember Rai used "video-ish" word (or alike) to describe image from ccd, even thought its a larde and quality sensor. Is it there that big difference?
Wayne, i looked for alternative, even in russia, here near my country, but with no paticular result. It seem that FF and micron has simply best technology, (and altasens' webpage is similar to zero, beatifully colored zero, to hell with em).
Konst Seraf is offline   Reply With Quote
Old April 24th, 2005, 11:12 AM   #374
Konstantin, regarding the wholesaler/retailer issue, that is a very good question. As I have been reading these forums for the last 6-8 months with a great deal of excitement I have however kind of had to temper it with the notion that these cameras may not be available to us on a single unit basis. For example are SI or Summix wholesalers that require you to be a dealer or require one to purchase multiple units? Wayne or Obin maybe you guys can shed some light on this issue. If not SI or Summix are any of the other chip makers disscussed or that either of you guys know about, willing to sell single units. If not then perhaps the best idea is to put together a group who are willing to buy (say 10-15 units total)....i think that someone was trying to do that a while ago if i am not mistaken. Anyhow please forgive the ignorance....i've just come across conflicting info and would like to know the answer once and for all.
thanks,
Omar
Omar Saad is offline   Reply With Quote
Old April 24th, 2005, 05:34 PM   #375
Not sumix, they are one of two companies that ever replied me about price and availability of their cameras. Second was elphel which is very, very helpfull if they only had 2/3 sensor cams. They claim their micron 1/2 gives beter picture than FF ibis5.
So sumix, there was additional questions to them. Especially, concerning global shutter implementationa and framerates/bitdebth. As far as they write at their SMX-150M webpage, 24bit 24fps even 1280*720 dont go via usb2. So its either lower resolution, framerate or bits. So i hope ill get clear these questions.
concerning idea of group order, i doubt its possible. Lets say we have 10 ppl that agree to order 10 ideal camera heads, which is at least 2/3 1980*1080 100fps through cheap interface with all api etc etc at $1500. But It doesnt exist. So here start compromise, and everyone has its own priorities.
For example, my dream solution would be to buy 10 Microns M413 (large hi-speed sensor used for rapid cameras with 4Gigs of ram onboard). So then hire somebody to develop sensor board with any common computer interface to put raw data directly to ram buffer, and make it an opensource project (or cooperate between owners) to quickly produce drivers, c-libraries etc. It was written here the micron costs around $900 (which qantity?).
