#181 |
<<<---Have you made a working relaylens for the XL-1????--->>>
Yes |
#182 |
Would you share how you made it???
Perhaps you could reply on the Canon XL-1 Relaylens for use with the 35mm adaptors thread (so this thread isn't messed up): http://www.dvinfo.net/conf/showthread.php?s=&threadid=23377&perpage=15&pagenumber=7 Thanks! |
#183 |
I am interested in Les' Kit too
Hi Les,
Just want to let you know let you know I am interested in your kit too. I also would be interested in getting an email from you as I have a couple of questions, including about the possibility to adapt your kit for medium format GG (see Brett's posts), as I am using a DVX100 and would be glad to get rid of one lens and get some extra contrast and brightness at the same time. Thanks in advance for your reply. Best Regards, Emmanuel |
#184 |
Les,
Could you send me some information as well? My email, if you can, is admin at weet.us |
#185 |
Email sent.
-Les |
#186 |
Micro35
Me too!
jamey at sunrushmusic.com |
#187 |
I'd be interested as well Les.
jon1million at sympatico.ca Thanks! |
#188 |
Hi Les
How is the osc. device coming along - any news? |
#189 |
OK. I'm a complete newbie to this whole 35mm adapter concept.
I have been doing my best to read through all these threads (there's a LOT of material to sift through!) but I may have missed a few posts (in fact I'm sure of it). Firstly, I've gotta say this is really a fantastic project! Congrats and kudos to everyone working on these. I'm bitten by this 35mm bug, and had a few ideas I was considering for my own project and was curious if anyone has had success or failure with any of this.... 1) What about a small speaker connected to a tone generator for an oscillator? Would that be too weak? Maybe it depends on the mass of the GG material. 2) Would a "frosted" bit of transparency (overhead projector "film") on a slide frame be a sufficiant focal plane, or is genuine ground glass the preferred medium? 3) I've seen broken camera bodies of all makes on ebay in the $10 range. Could the front plate from these be used for a lens mount? I have several Minolta lenses which are now mostly unused since I went digital. Would be great to put them to use on my GL2. :) Thanks. |
#190 |
thank you agus
Hi welcome aboard I feel guilty not offering advice at what won't work. I think after building everyone of the devices. the second augus 35 in the americas. this needs to be built in a optical tube
there is no way to get pvc , plastic project boxes , or even lens tubes to the tolerences we need . I am proud of my agus35 and bring it out @ every party. I think the focal length of 50mm camera lens to ground glass is about 1 1/4 inch thorlabs sells a stackable tube 1 1/2 that will fit a50mm 1500 grit ground glass that cost $14 a50mm plcx behind this and you have your static adapter. the cool part is these parts are the base for a ocillating adapter I am building . the empty lenses tube model was good but the tubes could not handle the weight of the camera lens and get a precise focus with the ground glass . I t came apart and died a glorious death in times square. you can all wait untill my parts come in and I will tell you how all this works. |
#191 |
Hi Anders and others,
I am busy adding some CNC to my milling machine, so I haven't got to the next stage of improving my oscillating GG mechanism yet. I do think there are enough people to go ahead with a limited production run of these, for $400 each. I will prepare a simple web page for easy information gathering for those who want one. Again, if you are interested and want to see the high definition video clip of my prototype in action on a rack focus, send me an email an I'll send you a link. I have to do this with email because last time hundreds of people downloaded the 22 meg clip and used up my bandwidth! Thanks -Les |
#192 |
Just curious, for those of you who have built versions of these before what is the focal length of a 35mm lens in, say, inches or mm? Does it change dependent upon the manufacturer?
#193 |
focal length
I think the distance is 1 1/4--- 1 3/4 for slr lenses. If you build the system in this tube you could adjust it to any slr lens thread retaning ring to focal point add ground glass and plcx and you have a static adapter .http://www.thorlabs.com/ProductDetail.cfm?DID=6&ObjectGroup_ID=213&Product_ID=1481
#194 |
ocillating adapter
this is the link to a cage similar to the one I plan on using for the oscillating adapter . It will fit precisely on the tube system the other end will also have more of the tube system then to a c-mount then lens. from one end of this tube to the lens .the tolerences will be perfect. the failure of my filter ring system
was the tolerences . this has to be perfect. http://www.thorlabs.com/ProductDetail.cfm?DID=6&ObjectGroup_ID=183&Product_ID=474 |
#195 |
Re: ocillating adapter
Yes, the tolerances are the critical part of this design. The alignment of the bearings and the shafts is the hard part.
The one I make has to be good enough for my JVC HD camera, which shoots 1280 x 720 video. Not much room for error! -Les <<<-- Originally posted by Richard Mellor : this is the link to a cage similar to the one I plan on using for the oscillating adapter . It will fit precisely on the tube system the other end will also have more of the tube system then to a c-mount then lens. from one end of this tube to the lens .the tolerences will be perfect. the failure of my filter ring system was the tolerences . this has to be perfect. http://www.thorlabs.com/ProductDetail.cfm?DID=6&ObjectGroup_ID=183&Product_ID=474 -->>> |
