Mini35 Oscillating Ground Glass Idea - Page 11 at DVinfo.net
Alternative Imaging Methods
Old August 31st, 2004, 10:58 PM   #151
Ray, I just used the GG and 50mm lens, no condenser lens used. It does get a tad darker on the edges, but not much.
My assembly is only 3.5 inches in diameter, so the motor has to be offset with a mounting plate.
-Les
Les Dit is offline   Reply With Quote
Old September 2nd, 2004, 02:47 AM   #152
Les.
Did you receive the DVD+R disk yet?
Old September 2nd, 2004, 10:27 AM   #153
Yes Bob, Sorry, I meant to reply but I was sidetracked!
The footage looks great, there is really no grain or other artifacting going on. Good work!
Thanks again!
-Les
<<<-- Originally posted by Bob Hart : Les.
Did you receive the DVD+R disk yet? -->>>
Old September 2nd, 2004, 06:34 PM   #154
Les, could you email me a link to your footage?
film AT bigsmile.com
Also, do you have any photos of your unit? That would be very helpful too.
Joel Aaron is offline   Reply With Quote
Old September 9th, 2004, 10:07 AM   #155
Hey Les,
I wouldn't mind seeing that footage of yours. Can you link me up?
elrosten@yahoo.com
thanks
Jesse Rosten is offline   Reply With Quote
Old September 9th, 2004, 11:53 AM   #156
OK, link sent. Let me know what you think!
Old September 9th, 2004, 02:04 PM   #157
Looks great. I see no grain. And I'm sure the jitter will go away when the unit is mounted solidly to the camera.
This may have been mentioned a while back, but by oscillating a focus screen ( like from a 35mm or medium format camera) with a fresnel already "built-in" to the ground glass, you should be able to do away with all the condensor madness. The fresnel lines should be invisible because the screen is moving.
anyways... What's the noise level on your oscillator?
Old September 9th, 2004, 02:09 PM   #158
It seems like the fresnel type ground glasses are built with the rings relative to the center of light, so that it distributes the light across the plane. Rotating a fresnel with the axis being along the center of the rings would work, surely, but would oscillating it work without having some jittery unevenness? Does this make sense? Sorry if I've confused anyone.
Frank Ladner is offline   Reply With Quote
Old September 9th, 2004, 02:29 PM   #159
Jesse,
I didn't use a condenser on that test. Did you notice?
-Les
Old September 9th, 2004, 02:37 PM   #160
Yes, Les, The vignette was quite obvious. I wasn't trying to imply that you WERE using a condenser. - Just thinking aloud about the possibility of oscillating a fresnel-type focus screen.
peace
jesse
Old September 10th, 2004, 02:17 AM   #161
Oscillating a one piece fresnel/GG
"This may have been mentioned a while back, but by oscillating a focus screen ( like from a 35mm or medium format camera) with a fresnel already "built-in" to the ground glass, you should be able to do away with all the condensor madness. The fresnel lines should be invisible because the screen is moving."
Unfortunately you cant do this without another problem showing up. If you do you'll find out that your hot spot has suddenly reappeared when the fresnel is put into motion.
This happens because the fresnel is focusing light roughly to one point. When you move the fresnel in any way your changing where that point is pointed as it relates to the CCD's. Bigger the motion worse the hot spot effect will be. Now IF you could get it to oscillate in a path that is extremely tight (I mean no more than 1 or 2mm) then it shouldnt cause any problems at all. But having such a small movement means you'll have to move it quite a bit faster in order for the grain of the GG to "disappear". This is exactly what Im currently attempting to do. I'll let you all know if it works.
Brett Erskine is offline   Reply With Quote
Old September 24th, 2004, 11:05 AM   #162
<<<-- Originally posted by Les Dit : OK, link sent. Let me know what you think! -->>>
hi
can i see the footage as well. also has anything really come of the oscilating GG idea. im planning to shoot with and xl2 and some sort of homemade mini35 device with can ef lenses.
lilbowrabi@hotmail.com
Rabi Syid is offline   Reply With Quote
Old September 24th, 2004, 11:05 AM   #163
hi
Old September 24th, 2004, 12:17 PM   #164
Link sent.
-Les
Old September 27th, 2004, 07:00 AM   #165
I want to see!
oolsen1@ec.rr.com
Obin Olson is offline   Reply
