Using the EF Adapter instead !! - Page 3 at DVinfo.net
Alternative Imaging Methods
Old May 24th, 2004, 06:20 PM   #31
not to mention it makes the camera look freakin cool... post that pick at the photo of you rig thread in the xl1 section...
Josh Brusin is offline   Reply With Quote
Old May 29th, 2004, 01:57 PM   #32
Bernard,
it seems there is something wrong with the address !!
maybe from my end, i dont know,
but thanks man for the link anyways :)
Regards,
Amr
Amr Toukhy is offline   Reply With Quote
Old May 30th, 2004, 01:31 AM   #33
Hey Amr.
I thinks the problem is from your end because I checked it and it works.
Try it on another computer.
Regards.
Bernard Diaz is offline   Reply With Quote
Old June 15th, 2004, 11:25 AM   #34
<<They will be different on the XL1. Look at 28 days later. It was shot with Canon lenses and on an XL1 - not on a mini35. Looked great but different.>>
That's not exactly an accurate comparison. 28 Days Later was shot with Canon EJ and FJ cine lenses, not the EF still lenses. The quality of the EJ lenses is many, many times better than EF lenses. And they did have a mini35 adaptor, just not the P+S one because the movie was shot before it was released (it was filmed in the Fall of 2000). Instead, they spent a ton of money haveing Optex custom build a mini35 adaptor that would do the same thing the P+S one does. Those are the kinds of things you can do when you have a ton of money (the budget on that movie was, I believe, about $15 mil. US).
Personally, I don't know why Optex never released their adaptor to compete with Technik one. Maybe there was a rights issue with the producers of 28 Days Later since they paid for it. I don't know.
Joshua Starnes is offline   Reply With Quote
Old July 18th, 2004, 07:01 PM   #35
i just found this site for an ef adapter by xl1solutions. it claims to have a magnification of only 2X to 4X using their adapter and an ef lens. has anyone tried this adapter out? it seems like it would a better solution than canons ef adapter if it truly is only 2 to 4X.
they also have other mounts if you guys are interested. i am only interested in the ef adapter at this time but want to hear from others who may have more experience with adapters. it seems to add only a small amount of distance (maybe less than canon's) to the lens plane so it might in fact work as stated. would love to know for sure!!!!
thanks....
hope it helps others....
marc
www.zenimage.com
The brave may not live forever, but the cautious do not live at all....
Marc Sacco is offline   Reply With Quote
Old July 18th, 2004, 07:03 PM   #36
might help if i included the address!
http://www.xl1solutions.com/
www.zenimage.com
Old July 18th, 2004, 07:13 PM   #37
Marc, Please take a look to this thread http://www.dvinfo.net/conf/showthrea...t=xl1solutions for infos on this specific subject. Basicly, the XL1solution adapter is a mechanical adapter, and like any mechanical adapter, you will have a manification factor based on the CCD size and the type of lens used. With an 1/3 CCD, the magnification factor is about 7x if you use 35mm still lens, about 4x if you use 35 mm cine lens, or 2x if you use 16 mm cine lens.
Hope this help.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old July 18th, 2004, 07:26 PM   #38
Warden
No, read the explanation again. A mm is a mm. The use of different lenses will not produce different results. A 5mm lens is a 5mm lens. The magnification factor changes as the size of the format changes, not as the type lens changes. The XL1 Solution Adapter is no solution. It does exactly what the EF adapter does, no more, no less.
Jeff Donald
Carpe Diem
Old July 18th, 2004, 07:28 PM   #39
jean,
thanks! this helps alot. i understand now why the adaptors work the way they do! i think my best option at this time would be a 3x wide angle lens (until i can afford a mini 35 set up!)
also, jean (off topic) have you started your stabilizer rig? im buying the parts this week!
thanks again!
www.zenimage.com
Old July 18th, 2004, 08:44 PM   #40
Yes Jeff, sure, a mm is a mm, perhaps that I could have been clearer. What I mean is that if you point a still 35 camera with a 50 mm lens on it on an object, and after that you take the same lens on an XL1, assuming the distance between the object and the two cameras remain the same, this object will be 7x bigger on the XL1. That is how I understand the magnification between formats. Correct me if I am wrong.
Old July 18th, 2004, 08:51 PM   #41
Warden
Yes, your explanation is essentially correct.
Jeff Donald
Carpe Diem
