Thread Tools
Search this Thread
Magnification Factor
Hey guys--Reading through one of the old threads on the mini35 I get the impression that there is a magnification factor with focal lenghts when using the system. Is this correct? And if so, what is it? Thanks!
Peter |
RED Code Chef
To the best of my knowledge there is no magnification, that's
the whole idea behind the adaptor. You are probably thinking about the Canon adaptor?
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Sales: Reflecmedia
There is no magnification factor in regards to Academy35 shooting.
If you are relating your experience shooting SLR cameras to the Mini35, there is a conversion factor of approx 1.6x peace and vaya con dios, mizell signing off
Posts before Feb 2004 were on behalf of ZGC, afterwards they're all mine! |
Thanks Mizell. Just to make sure I understand, a 100mm lens used with the mini35 would give you the equivalent image (roughly) of a 160mm SLR? Thanks!
Peter |
#5 |
Moderator
Hello Peter,
Yes. Bear in mind that the actual frame size of a 35mm still image is larger than that of standard Academy 35mm motion picture film. Take a look at the following "Angle Of View" Chart that details the differences at http://www.edward.grabczewski.btinte...le_of_View.xls. (Use a Spreadsheet program to open the file such as Microsoft Works or Excel) You may want to take advantage of the "Search" button at the top right of your screen. Try entering a keyword search string of "Mini35 angle of view". You'll be able to take advantage of the fact that this issue has been addressed multiple times here in the forums. That Search Tool is an immensely useful feature for finding posts related to most any topic you may have such as this one: http://www.dvinfo.net/conf/showthrea...l&pagenumber=1 Please do let us know if you have any other questions and please do keep in touch. Many thanks, - don
DONALD BERUBE - noisybrain. Productions, LLC Director Of Photography/ Producer/ Consultant http://noisybrain.com/donbio.html CREATE and NETWORK with http://www.bosfcpug.org and also http://fcpugnetwork.org |
#6 |
Thanks Don, I will check it out.
Peter |
