35mm Adapter Static Aldu35 - Page 77 at DVinfo.net
Alternative Imaging Methods
Old November 30th, 2004, 10:55 AM   #1141
I have a Sigma 28mm which fits to the Nikon mount on the front of my version but I have had extreme difficulty in getting a sharp image. I did get a better result with a Cimko 28mm to 85mm zoom but it was f3.4 and went dark on full zoom. On the non-erecting version it was acceptable and my music video test "My Time Again" was shot on it.
In conversation with some people who hire equipment here, the consensus was that the Agus or Mini35 for that matter would probably be best employed if the wide-angle footage was shot direct to camcorder and the Agus kept only for head shots and the depth of field work.
Old November 30th, 2004, 12:20 PM   #1142
Interesting. Any idea why that might be?
Aaron Shaw is offline   Reply With Quote
Old November 30th, 2004, 12:32 PM   #1143
well, I shot a full 82 minutes movie using the Mini35 without any image quality problem if this helps.....
Juan M. M. Fiebelkorn is offline   Reply With Quote
Old November 30th, 2004, 09:34 PM   #1144
Juan.
I forgot to mention in my previous post, we were talking about shooting high definition TV.
The Agus version I have built certainly would not compare favourably with the Mini35 in a production environment as it has to be managed with gentle care as I have discovered in my most recent test or the results will be inconsistent.
What lenses did you use on the Mini35?
Old December 8th, 2004, 12:37 PM   #1145
I have some test footage using Mylar instead of glass or plastic in the GG position. I took a 35mm lens and basically rebuilt it for this. I took just the lens part and put it in a piece ov PVC, using just the basic gearing for focus. here the footage www.hazardousproductions.com/test.mov. Not a great camera job but the point is there.
i am the muffin man.
Fred Finn is offline   Reply With Quote
Old December 8th, 2004, 02:42 PM   #1146
I used PL mount, Carl Zeiss f 1.2 lenses..
Old December 8th, 2004, 03:58 PM   #1147
Anamorphic 35mm lens
I've built a 35mm lens adapter for my Sony vx2000 Mini DV camcorder. In FCP, obviously there is an anamorphic setting in sequence settings and capturing settings, but it is only for 1.78:1 (16X9). Is there a way to tell the system that I'm actually using an anamorphic lens that compresses the image 2:1, or even 2.25:1? I think compressing the image manually after capturing will degrade the resolution.
Donnie Wagner is offline   Reply With Quote
Old December 8th, 2004, 09:00 PM   #1148
Fred: wouldn't mylar cause a dramatic light loss? Isn't that stuff highly reflective?
Old December 8th, 2004, 09:51 PM   #1149
Their are different kinds (i think not 100 sure). The stuff i have is flat, not glossy. The test video i have is only natural lighting. aka sun...
Old December 8th, 2004, 09:54 PM   #1150
Ah ok. Thanks for the info Fred :).
Just out of curiosity, what camera did you use for the test?
Old December 8th, 2004, 10:08 PM   #1151
Gl-1. How'd it look?
Old December 9th, 2004, 09:41 AM   #1152
It was hard to judge how the actual adapter performed due to the fairly strong backlighting. Things were either pretty dark or over exposed.
Old December 9th, 2004, 08:45 PM   #1153
can anyone here from Australia please tell me where they bought aluminum oxide from. i'm having a fair bit of trouble finding a source.
Matt Ziegeler is offline   Reply With Quote
Old December 9th, 2004, 10:37 PM   #1154
Francis Lord Optics supplied me with some AO5 on request when I bought my 40mm prisms from them. "sales@flo.com.au". I don't know if they will do small orders alone.
Old December 10th, 2004, 05:26 AM   #1155
thanks i'll give them a try, of course is any one out there has any other sources that would also be very helpful. Theres just so much information to wade through that its tough to find specifics.
