Some MINI and PRO questions - Page 2 at DVinfo.net
Alternative Imaging Methods
Old January 28th, 2004, 01:55 PM   #16
Barry Wan Kenobi
<<<-- Originally posted by Mizell Wilson : Barry,
What we're trying to hash through is the conversion factor for achieving similar compositions between formats e.g. Hope this clears up the confusion.
mizell -->>>
Okay, cool. That's easy. Here's a chart that converts angle of view among basically every film and video format made:
http://www.edward.grabczewski.btinte...le_of_View.xls
From that chart it looks like a 50mm on a still camera delivers the same field of view as a 30mm on a movie camera. And a 175mm on the still camera would match the FOV of a 100mm on the movie camera.
Old January 28th, 2004, 02:22 PM   #17
Sales: Reflecmedia
Cool Barry, great find!!!!
Posts before Feb 2004 were on behalf of ZGC, afterwards they're all mine!
Mizell Wilson is offline   Reply With Quote
Old January 28th, 2004, 04:47 PM   #18
Ahh, that is a goodie. Sorry I wasn't making myself clear, even after my attempts at clarification!
It looks like 1.6 is a good number then, give or take a bit. I'm still wondering if there is a loss or gain in field of view due to the re-photographing aspect of the Mini35 setup, which I think I will just have to wait and see until I can do a side-by-side comparison with a film camera.
My interest here is mostly if I was presented with a still lens-equipped Mini35, how to choose the appropriate lenses since I am used to thinking 35mm cine focal lengths.
A couple of thoughts about this: since the still lenses are designed to work with a larger target than the cine lenses, would it not be the case that on a Mini35 we are only using the center of the still lens, which would help with edge distortion/chromatic abberation-type issues, if present?
And here's another thought for discussion: if the Mini35 theoretically had a target size similar to a 35mm still camera rather than a cine gate, would you not be realizing a decrease in depth-of-field (i.e. shallower) given the same field of view? In other words, we are using a (theoretical) 30mm cine or still lens on the Mini35 to achieve a particular composition, but if a 50mm still lens was used on an imaginary version of the Mini35 with a larger ground glass and the appropriate relay lens, we would net the same composition but less depth of field, due to the longer focal length. If this is so, perhaps the Agus35 crowd may be getting even more bang for their buck, if they are capturing a full 35mm still frame
Charles Papert
www.charlespapert.com
Old January 28th, 2004, 04:52 PM   #19
Sales: Reflecmedia
Hey Charles,
Yes, theoretically we are using more of the center of the still lenses, helping to increase their overall quality...one reason why I think they're holding up to the cine lenses so well.
The Mini35 could certainly have a still sized image screen. The unit actually started out capturing S35, for that extra tad of shallow, but the problem existed that almost all cine zooms and some older primes were never designed to cover S35, resulting in the soft vingettes that were reported early on. So for maximum compatibility with maximum results the Academy 35mm was chosen.
mizell
Old January 28th, 2004, 05:53 PM   #20
Now that we seem to be in agreement, is it not time for P+S to consider a version Mini35_SP (Special Performance) to account for the larger SLR frame with the appropriate change to FFD?
This will be essential, especially to capitalise on say the Nikon 35mm f1.4 which has amazing point of presence properties and would very likely suck the audience out of their chairs and into the film.
I would love to see a blow up with such a setup
as far as CA and BD distortion, After Effects Plugins are sufficiently well developed to rectify any present and could easily be incorporated into a work flow along with breathing issues (which incidentally only account for about 3% image scale over the whole travel of the focus ring)
FYI
http://www.mir.com.my/rb/photography...kkor/index.htm
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old January 29th, 2004, 02:10 PM   #21
Sales: Reflecmedia
I doubt we'll see a version of the Mini35 designed to use the full 35mm still aperture for many reasons.
One is that I think one reason we're getting such great results with the Nikon lenses is because were not using the full image circle.
There is also the relay lens to consider. Reducing the Still image circle to 1/3" would start to stretch it's capabilities.
With those two things combined I think we would see a lot more of edge distortion than might otherwise not be seen because of how forgiving film can be.
Never say never though :)
