Let me throw a dumb question in the middle here... at DVinfo.net
Alternative Imaging Methods
Old January 21st, 2004, 08:46 AM   #1
In going the non-spinning glass route,
what is the primary difference between
using a homebuilt 'AgusTube' as opposed to
Canon's EF Adapter for the XL1?
Scott Moore is offline   Reply With Quote
Old January 21st, 2004, 12:33 PM   #2
The one major difference is depth of field. The larger 35mm image projected onto the ground glass (Agus's model) provides for a more shallow depth of field than the 1/3" ccds (1/3" = 8.5mm) of the Xl1. With the EF adaptor, you're just adding a lens (like looking through a window) but with the ground glass, you're actually looking at a much larger, flat surface projection of what's coming through the lens.
Nicholi Brossia
Nicholi Brossia is offline   Reply With Quote
Old January 21st, 2004, 12:43 PM   #3
another difference is that with the Ef adaptor or any mechanical adaptors, you will have a magnification effect of 7.2X due to the difference of size between 35 mm film and 1/3 " CCD. By using a ground glass as a projection screen like the Mini35 or Agus's version, you preserve all the caracteristics of the lens used.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply
