Homemade 35mm -- Edited Copy for Reading - Page 11 at DVinfo.net
Alternative Imaging Methods
Old December 11th, 2003, 06:50 AM   #151
Update:
Went over to best buy where they are selling a very cheap cd player/discman for 17.99 with a 5 buck instant rebate... so 12.99 plus tax leaving the store. Took this thing apart with a srewdriver and found that the motor that spins the disc can be completely seperated from the rest of the board and stuff... giving you the red and black wires off of the motor in which to hook up to a battery pack (which you can get at radio shack... I have a 2 triple A pack.) In between I also have wired a on off switch (also from radio shack). And believe me if I can do this... anyone can because I don't know crap about electronics. This is also the best way to do this thus far. The radio shack toy motors Agus reccoments make WAY too much noise, not even usuable with a boom, and vibrate WAY too much (that could be fixed with a stable design but why not just spend the extra 10 bucks and get the cd player motor and you won't spend endless house trying to center the cd on the toy motor and kill yourself when you realize the shots look great but you'll never be able to reccord dialogue with a device using that motor). So believe me... use the cd motor!
I am using a wide angle adapter I had (minus the wide lens like agus is doing) for my trv20 on my sony pd150. Problem is that you must zoom in a little to get away from the vinnetting of the actual lens. I went to NEWTONVILLE CAMERA looking for a macro lens and first off the clerk on the phone told me this adapter was not possile and tons of people were coming into his store recently buying and returning lenses, no one ever successful. I went there and proved to him that it does indeed work, however he was unable to produce me a 58mm threaded macro lens that would work with this device. (he had some macro lenses but they went out of focus before you could zoom out the vinnetting.)
Peter Sciretta is offline
Old December 11th, 2003, 07:26 AM   #152
I also managed to remove the motor from an old, broken CD player I had--only broke a few weeks ago, too, good thing I didn't throw it out! Stripped the wires, tapped 'em to a AA battery, thing spun up just fine. Best thing is, since it's a portable player, it has the little springy-ball "clip" style spindle. Holds the CD in place without glue, and spins at a nice speed (I think).
Now I just gotta get the equipment necessary to mount this bad boy to my VX2000, and the means to attach a lens to the front, and I can finish this project.
Robert Martens is offline
Old December 11th, 2003, 09:16 AM   #153
Peter or Robert, what was the model of the cd player or is it just any old cheap discman? I might buy it today and finish my version of the Agus35 using 35mm film cans by tonight. I already got an image and i just want to better stabilize the system by using another can before i post pics. I'm using tiffen macro lens +1, +2, +4 combined for a +7 for $39 at a local photo store. It worked out fine, but it seems using the cd motor might be the solution to the vibration sound problem.
Peter A. Smith is offline
Old December 11th, 2003, 09:51 AM   #154
For Peter Sciretta. - I used a generic 42mm eyepiece of chinese origin to fit Tasco telescopes, extracted the lenses to make up an adaptor from PD150 to PNP-HG night-vision intensifier. This frames the 18mm diameter display tightly top to bottom when the zoom is wide and corner to corner at about 25% in. It wouldn't be any use for the 35mm image frame size but a lower power two element lens set of similar design might.
In my early prototyping I used a similar less powerful lens set in a sub-assembly out of a Sony VCR16B telecine adaptor (a 16mm C mount lens, a macro spacer, a mirror, a ND filter and the two lenses in a module, all enclosed). This framed closer to the 35mm frame size and needed a lot more zoom to come in to frame onto the 18mm diameter display tube target.
There might be some benefit in experimenting with 90degree consumer telescope eyepieces and barlow lenses. I think the eyepiece lenses may be too powerful, but there may be something there - just a thought.
Both of these lens sets I describe do not erect the inverted image.
Bob Hart is offline
Old December 11th, 2003, 10:37 AM   #155
Just to tie some loose threads:
Agus's sugestion of finding a "cheap wide angle" with macro is fine, but you have to be sure you're getting one large enough for your lens's threading. For the GL1/GL2's out there, a good choice might be this one. Not sure if the VX2000 has the same threading...
CD motors are great design choices -- they're so quiet.
Uhm, that's it for now.
- jim
Jim Lafferty is offline
Old December 11th, 2003, 10:38 AM   #156
For those using a CD motor - AWESOME! I am glad it worked. Could you tell me how far you are putting the CD away from the lens, I mean are you having to extend it out very far (I know this will differ for different cameras, but I am speaking in general). And, if you are, how are you doing it? I will be making the trip to Best Buy soon...thanks for the info Peter!
Clay
I understand everything about nothing.
J. Clayton Stansberry is offline
Old December 11th, 2003, 11:38 AM   #157
Peter -
In answer to your question about the telephoto lens adapter ... the slide on the bottom of the support has a screw to adjust the length of the arm. So you'd have another 6" extension that you don't see in my photo.
Sorry for the lagged response (been very busy during Christmas season). Can't wait to get back to work on this project.
Richard
Richard Mellor is offline
Old December 11th, 2003, 02:09 PM   #158
I have been getting all my materials together to build an Agus35 with a DVX100. I bought a 30 pack CD spindle but I am not sure where i should place the spinning CD. Would it be better to place it by the Camcorder lens or the SLR 50mm lens? Should you place the CD as close to the lens as possible?
Louis Grimaldo is offline
Old December 11th, 2003, 02:17 PM   #159
Ok folks ....i have some test video ...from a very very basic agus35. ......Let me just say that .....the video example is very poor quality. ....nothing at all like agus' videos. ....This is strickly a test.
www.elpez.com/agus35test.mpg
Here's what I did. ...I took a cardboard box ...cut a hole in each end ....stuck my vivitar lens in one end ...and the canon gl2 in the other end. ....i slit a hole in the top ....and stuck a sand papered clear CD in the top ....then i just shot some video. .......
A few notes
Lighting is definitely a problem ....As you can see ...it was very dark ...and I had the settings cranked up pretty high in the gl2
Another thing .....Agus recommened using 600 grit sandpaper ....I didnt have 600 ....so i used 150 .........as you can see it puts huge scratches in the CD ........Also .......as you can probably see ....the CD (ground glass) ...is not spinning. ....
Aaron ......I posted a question about the round bright spot .....I fixed that problem ..... ..I hadnt sanded the CD enough. ....I took the CD out ..sanded it some more ...and that ...essentially diffused the bright round light.
Hope i didnt offend Agus by constructing such a bad test agus35 ...
let me know if you have any questions or comments
chris.
Chris Black is offline
Old December 11th, 2003, 02:34 PM   #160
<<<-- Originally posted by Louis Grimaldo : I have been getting all my materials together to build an Agus35 with a DVX100. I bought a 30 pack CD spindle but I am not sure where i should place the spinning CD. Would it be better to place it by the Camcorder lens or the SLR 50mm lens? Should you place the CD as close to the lens as possible? -->>>
it depends on your lens and camera, like mine is 1 3/4" away from the 50mm ans 3/4" away from the camera.
Just experiment untill you get a clear projection on the gg.
hehe...I guess I better let the cat out of the bag now- (mine is adjustable :) I will post some pics of my setup in a while.
The glory of the World passes by.
John Gaspain is offline
Old December 11th, 2003, 05:00 PM   #161
posing a thought ...and asking a question ....
isnt there some sort of material out there ...like wax paper .....that you could put in the place of the GG ........like ..the translucent screen in an SLR camera. ......that way ..you could have a clean enough image ..without having to spin the projection screen (ground glass)
my question is ......what percentage of the original picture ...(720 X 480) are you losing.......by zooming in to the image close enough to eliminate vignetting.
for exampe ...are you ending up with ....a 680 X 420 image?? ....
chris
Old December 11th, 2003, 05:34 PM   #162
OK I'll take a stab
# 1 even a very pure frosted (Wax Paper) type substrate is going to have issues because your taking 24-30fps it going to look like your filming thru a screen because the grain will not change overtime, unlike film who's grain is organic like due to changing it's pattern every frame. at least thats my take on it.
and #2
your not losing any resolution because you have not hit the cameras CCD's yet they are going to take a 720X480 sample of what ever they see.
I'm working on my plans right now, I really look forward to seeing what everyone comes up with.
Luke
Luke Andrews is offline
Old December 11th, 2003, 05:43 PM   #163
heres my version,
im still experimenting with having to zoom slightly. I think that I can get the camera closer to the gg.
the gg is adjustable by moving the fan frame along the guide bolts.
I have a fresnel lens 1/8" away from the gg mounted on guitar wire.
I am using a Sima wide angle lens that I got at Bestbuy for $30 then removed the WA lens portion leaving the macro in place, If I just move the cam 1/2" closer I have a great picture without zooming, but I dont have a good way to secure it properly so I left it alone for now.
I also noticed that the final image is very dark, I might need a lighter gg
http://www.imagestation.com/picture/...4/fa531005.jpg
http://www.imagestation.com/picture/...8/fa531004.jpg
http://www.imagestation.com/picture/...c/fa531009.jpg
http://www.imagestation.com/picture/...c/fa53082e.jpg
http://www.imagestation.com/picture/...8/fa528f0c.jpg
gaspain
Old December 11th, 2003, 06:35 PM   #164
<<<-- Originally posted by Jon Yurek : Interesting. VERY interesting. I may have to steal your idea of using the fan casing when I make mine. And is that a fresnel lens in the shot where the CD is off? -->>>
ya thats the fresnel, im still unshure of the proper distance away from the GG, rit now its about 1/8" away (1/4" would be better)
Im pretty happy with using the fan. Its quiet and smooth. I used a part from an old DVD player to hold the CD, gluing that on center of the fan was a pain to get it centered. I also had to trim alot of plastic of the shroud with a mill so the GG wouldnt rub.
Old December 11th, 2003, 06:38 PM   #165
Originally posted by John Gaspain : heres my version,
im still experimenting with having to zoom slightly. I think that I can get the camera closer to the gg...
Very cool. I'm using that same box housing from Radio Shack, but my design isn't nearly as industrial.
For those of you using the CD motor -- I noticed my portable CD player uses two "AA" batteries. Would upping that to a 9v stress the wiring or motor itself?
Also...my latest trip to Home Depot had me looking over the sandpaper section. I've already used 150 on my GG, and 600 was nowhere in sight. Agus, and others who've experienced success with their design -- can we see close-up, clean shots of your GG?
- jim
