Homemade 35mm Adapter - Page 53 at DVinfo.net
Alternative Imaging Methods
Old January 14th, 2004, 10:42 AM   #781
Hey guys I need a 37mm macro lens that will work with this setup. What do you suggest?
ScapeFilms.com | My Photography | IMDB Profile
Mike Tesh is offline   Reply With Quote
Old January 14th, 2004, 11:18 AM   #782
Re: Maxell CD-R???
<<<-- Originally posted by Jeremiah Rickert : Someone posted that the blue 25 pack of maxell cd-r's came with the frosted CDs. What is the spindle called precisely?
I picked up a blue maxell spindle, and it was $25, and of course when I cracked it open, no frosted CDs. They were called CD-R Pro and they were the only blue spindles at Office Max and Staples.
So....what's the precise name of the CD-R's with the frosted CD?
Jeremiah -->>>
Jeremiah,
I also almost made the same mistake. The packages are very similar, but it is the Blue 50 pack that says Maxwell CD-R only...NOT PRO. If you look through the top you should be able to see that there is a different CD on the top that is "fuzzy" rather than clear. I picked mine up at Wal-Mart of all places after not finding it at Best Buy, Office Depot or Target. Good Luck, and you won't be dissappointed when you get it!
I understand everything about nothing.
J. Clayton Stansberry is offline   Reply With Quote
Old January 14th, 2004, 02:04 PM   #783
<<<-- Originally posted by Mike Tesh : Hey guys I need a 37mm macro lens that will work with this setup. What do you suggest? -->>>
check this site. i think that it will be dificult to find proper +10 macro 37mm. maybr the solution is to buyadapter ring bigger than 37. i beleive that it's easier to find larger macro lens (49,52,58 etc...)
but anyhow - check this site. i didn't checked it properly, but just find it a while ago.
www.2filter.com
Filip Kovcin is offline   Reply With Quote
Old January 14th, 2004, 05:09 PM   #784
Part 1 of a very, very rough tutorial on building an Agus35 for a Canon GL1/GL2 or Sony VX-1000/2000:
http://ideaspora.net/agus35/
- jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Jim Lafferty is offline   Reply With Quote
Old January 14th, 2004, 05:44 PM   #785
Great Job Jim!
Great job on the tutorial. If thats rough can't wait to see the finished version. Do you plan to leave these pages up? If so do you mind if I link to them from my site?
Paul
http://www.thecountrybulletin.com/dv_dof.com
(Soon as I get time it will be www.dvdof.com)
Paul Doss is offline   Reply With Quote
Old January 14th, 2004, 07:26 PM   #786
Jim.
Lots of work obviously went into creating a very comprehensive tutorial.
Commendations are the order of the day here.
Old January 15th, 2004, 04:40 AM   #787
Where did you get the parts for connecting the lens and the GL1 Jim?
Stewart McDonald is offline   Reply With Quote
Old January 15th, 2004, 08:22 AM   #788
Folks. Chris has put the 16:9 comparison .jpg up for me at www.dvinfo.net/media/hart. You'll find it as aguswscr.jpg
The images were made with a Century Optics 16:9 anamorphic adaptor offered up to the front of the 35mm type lens. The right side image pair has scratches. Ignore those. I forgot to switch the groundglass on.
Old January 15th, 2004, 08:43 AM   #789
Thank you Filip however I was unable to find the lenses there. However I did some searching and found a lens set.
http://www.bugeyedigital.com/product...tif-02005.html
Not that expensive and can be used as just a +7, +10 or in combination as a +17
Good for anyone using Sony single chip cameras that have 37mm threading.
My JVC has a 27mm threading but I bought a step up ring off ebay for $5.50.
I found this site through this guys review of the filters:
http://www.pmichaud.com/wiki/Reviews/LensAdapter
Old January 15th, 2004, 10:45 AM   #790
Bob Hart,
I am sorry that I have not kept up with all of your posts, but could you drop an answer to if you are using real ground glass or not? Or, direct me to the page where you answered this? I know you have been working on it...thanks in advance.
Clay
Old January 15th, 2004, 01:21 PM   #791
Paul and Bob - thank you for your kind words.
I intend on keeping this tutorial up for quite some time, improving it as time allows, but keeping it at the same general locale - http://ideaspora.net/agus35 - so feel free to link away. I wouldn't mind if you mention my name on your page, though - Jim Lafferty - I'm making every effort I can to be recognized as a filmmaker and so every bit counts :)
As for this question:
The short answer is Home Depot. The long answer is I can't remember whether it was the plumbing section, or the electrical section of the store, but I spent a lot of time and quite a few trips getting all my parts. For the GL1, a conduit hub measuring 2.5 inches works perfectly -- for SLR lenses, a 2 inch hub works well.
Incidentally, as I'm building my rail system, a heads-up to any of you ambitious enough to make them on your own - Home Depot has a little nook with threaded rails that measure in lengths from one to six feet, with diameters of either 5/16ths or 3/8ths being best for our purposes.
I'm going with 5/16ths and pairing the rails with corner braces from the "hinge" department, some washers, bolts and wingnuts.
Incidentally, I've found that 5/16ths nuts -- for some reason -- do not thread onto 5/16ths rails properly. 5/16ths wingnuts, however, thread through just fine. Hence, you'll see the use of wingnuts with my rail setup...
Here are some images to give you an idea:
http://ideaspora.net/agus35/corner_brace.jpg
http://ideaspora.net/agus35/railjoint.jpg
http://ideaspora.net/agus35/rails_front.jpg
http://ideaspora.net/agus35/rails_front_detail.jpg
- jim
Old January 15th, 2004, 02:31 PM   #792
Hey that one looksl ike mine ! heheheh
nice rails dude, they are really useful.
BTW, i solve the flipping problem with a cheap pentaprism...
but if you lose too much lightin the process i solve it putting a telescope mount with prism inside at the end of the little viewfinder in the dv camera.
Agus35 - the ultimate tool for indie DV filmakers -
Agus Casse is offline   Reply With Quote
Old January 15th, 2004, 03:21 PM   #793
Agus where did you get the pentaprism from?
And is there any way you could put up a simple little diagram of how yours is put together with the pentaprism?
Don Mahr is offline   Reply With Quote
Old January 15th, 2004, 03:57 PM   #794
I found a source for REAL glass CD's!!!....well sorta. My buddy is gonna try and get one for me from a recording studio. Apparently they use glass CD's for master cuts of songs so they last forever called a "Glass Master" I should have more info in a few days.
WOO HOO!!
check this out http://www.disctronics.co.uk/technol...rep_master.htm
John
The glory of the World passes by.
John Gaspain is offline   Reply With Quote
Old January 15th, 2004, 07:08 PM   #795
Sorry Jim, I actually meant the parts connecting the 50mm lens to the adapter and the GL1 to the adapter?
