Homemade 35mm Adapter - Page 20 at DVinfo.net
Alternative Imaging Methods
Old December 11th, 2003, 07:50 PM   #286
Bob, you're actually close to the mark on how to create real ground glass. You basically take the grit, add a bit of water, and rub two pieces of glass together for about 20 minutes. Using that method you can create better-than-professional-grade true GG, if you take your time at it :-)
paulb
Paul Bettner is offline   Reply With Quote
Old December 11th, 2003, 07:57 PM   #287
<<<-- Originally posted by Peter Sciretta : i am using 2 AAA batteries (1.5 volts each) on the cd motor and I think thats going too fast and making more noise then it should... not nearly as much as the radio shack kiddie motors but noticable noise... any suggestions?
BTW: What project box size you guys using? -->>>
7x5x3, its takes a bit of heat to make the GG fit without rubbing
The glory of the World passes by.
John Gaspain is offline   Reply With Quote
Old December 11th, 2003, 08:02 PM   #288
what do you mean by heat?
Peter Sciretta is offline   Reply With Quote
Old December 11th, 2003, 08:03 PM   #289
Using a 9v battery....
may burn the motor out if it doesn't it will spin REALLY FAST!
I took the motor/CD holder out of an old portable CD player, snapped a CD into it and connected it to 3v. WHOA! It spins too fast. The gyroscopic effect was very pronounced and I was concened if my"Agus35 Mark 12 Pro Rev 1.0" was jerked to quickly the CD might come of holder!
I then connected it to a single 1.5v cell and its much better. It still spins at a good rate.
Tom
Tom Jensen is offline   Reply With Quote
Old December 11th, 2003, 08:08 PM   #290
<<<-- Originally posted by Peter Sciretta : what do you mean by heat? -->>>
fire, use a mini blow torch or windproof lighter to melt the inside of the box to fit
Old December 11th, 2003, 08:09 PM   #291
by fire/heat what exactly did you do to the box because i have the exact box and can't figure out how to make the lens fit?
Old December 11th, 2003, 08:32 PM   #292
<<<-- Originally posted by John Gaspain : <<<-- Originally posted by Peter Sciretta : what do you mean by heat? -->>>
fire, use a mini blow torch or windproof lighter to melt the inside of the box to fit -->>>
Old December 11th, 2003, 08:59 PM   #293
www.elpez.com/agus35test.mpg linked
Danny Tan is offline   Reply With Quote
Old December 11th, 2003, 09:47 PM   #294
Here are two pictures of my quick-and-dirty attempt to make one of these things. It works! Now I'm going to spend a few dollars and make a nice one.
The lense was biult into a 35mm camera and by the time I wrestled it out it could no longer be focused. I changed the motor on it and had to mount the lense backward to get it far enough from the GG. The big gash in the side is from only having 100 packs of CDs and having to cut a huge hole to shove my camera into.
http://vistatheater.org/~rhenry/agus...35-1-front.jpg
http://vistatheater.org/~rhenry/agus...s35-1-side.jpg
Ryan Henry is offline   Reply With Quote
Old December 11th, 2003, 10:17 PM   #295
For those looking for fine grit sandpaper, try the auto parts store in the paint section. They usually have really fine grit wet/dry paper for doing touch up or other paint/body work. I have gotten 1000 grit at auto part stores before. They should at least have 600...
I understand everything about nothing.
J. Clayton Stansberry is offline   Reply With Quote
Old December 11th, 2003, 10:33 PM   #296
I added an adjustable fresnel lens
http://www.imagestation.com/picture/...8/fa528f0c.jpg
edited to say: HELL YEA! thats what i needed! its adjusted out a little over 1/4". This fixed any vignetting.
Old December 11th, 2003, 10:54 PM   #297
John,
A couple of questions:
1. Where did you get the freznel lens?
2. Where did you get the fan?
3. Is the box the one from Radio Shack?
4. When are we going to see some footage with the fix?
5. Plans?
Agus,
How are your plans coming?
Thanks in advance...
Clay
Old December 11th, 2003, 10:55 PM   #298
Hey John, what tool did you use to cut such perfect holes in the box?
Old December 11th, 2003, 11:02 PM   #299
<<<-- Originally posted by J. Clayton Stansberry : John,
5. Plans?
Agus,
Clay -->>>
1-Walgreens $1.50
2-computer store
3-radio shack
4-I need a better GG, so in a while
5-Just look at the pictures for now
Old December 11th, 2003, 11:04 PM   #300
<<<-- Originally posted by Paul Bettner : Hey John, what tool did you use to cut such perfect holes in the box? -->>>
I used a hole saw attachment on my milling machine, a drill should work tho
