Letus35 Ultimate: Community Help and Opinion
I'm seriously considering purchasing my first 35mm Adapter. The Letus35 Ultimate Adapter Starter bundle for my Canon XH-A1 seems right for me.
---> Letus35 Extreme Starter Bundle*::*Letus Bundles*::*LetusDirect I was wondering what the DVI community's overall thoughts on the adapter are. Does anyone here prefer another brand and why? I've heard about HD Achromats - what's the purpose? Here are the specifics I'm purchasing with the bundle. If any options are incorrect or incompatible for the XH-A1 please let me know. Thread Size: 72mm Lens Mount: M42 Screw Mount (Is that compatible for all lenses?) Rod Support System: 30cm + 15cm Complete System (Is this the correct size for a standard xh-a1?) Additional Thread Size: None Additional Lens Mount: None Camera Optimization Kit: None Quantity: None And for heaven's sake...if your know anyone selling one -please let me know! Thanks again everyone! |
Anyone....?
One of the reasons you probably haven't gotten a response is that this is posted in the wrong section of the forum. You should go to the "Alternative Imaging Methods" section. That's where they discuss adapters.
Now that you have that wonderful information, I'll take a stab a some of your questions: First, there's a little confusion. You mention you are considering the Letus Ultimate but you posted a link to the Extreme. Those are two entirely different animals, not only in function but in price. Both are excellent adapters, by the way. The extreme uses a vibrating Ground Glass (GG); The ultimate uses a spinning ground glass (GG). Pros and cons: Vibrating - lighter more compact but has limits on fstop and shutter speed. Spinning - more flexible on fstop and shutter speed but is larger and more expensive Other companies to consider: Brevis MP.1 (Oscillating GG adapter) www.cinevate.com SGBlade (Spinning GG adapter) Welcome to shoot35! M2 (Spinning GG adapter) Redrock Micro: Create the Cinema Experience There are others but not as well known. Having built my own spinnng GG adapter I learned a lot about them. I ended up purchasing the SGBlade. It's a lot like the Letus Ultimate but a lot less expensive. If you want Letus, its a very good brand so you won't go wrong there. |
Im surprised this thread hasn't been moved. It has been a long week for me, maybe it has for our mods also ; ).
Anyhow. Save yourself the headache and stick with Letus. Extreme, or Ultimate if and only if you have the $$. The other adapters are nice but you should really do a search you will find some great GREAT discussions. Lens mounts BRAND specific. Start here: http://www.dvinfo.net/conf/alternative-imaging-methods/ JS |
#5 |
Sorry, John, but I have to disagree with that advice. I think it's well worth the headache to do the research and compare different brands to be sure Alex is getting what he needs. There may be specific aspects about the type of shooting that Alex plans to do that would perhaps be benefitted more by one adapter over another. For example, yes, the Letus is a great adapter. However, it has only one "look" with the image. Adapters such as the Brevis, M2, and the SGBlade allow you to change the GG to get a different look and different level of light loss. Also, if Alex plans on shooting with higher shutter speeds, or stopping down more, he would benefit more from a spinning GG adapter than a vibrating one. They all offer different lens mounts so that shouldn't be a factor.
It's always best to do the research and make sure that what you are about to spend lots of $$ on is what you need. |
#6 | |
With hundreds of new posts coming in every day, it's a big challenge to stay on top of thread moves. You guys can really help us out a lot by using the "Report Post" function found to the left of every post on the forum -- that gets our attention quickly, and we try to respond to move requests as soon as we see them. It takes less time to report a post for moving than it does to reply to the thread about its needing to be moved. |
#7 | ||
JS OH!.....and what I meant about the lens mounts is simply that you have to get a Nikon mount for Nikon lenses, Canon for Canon, etc...from the corresponding lens adapter manufacturer. |
#8 | |
Knowing about all of the options can give you a headache, as you mentioned, when it comes to deciding which adapter to purchase. But I'm sure you agree, that it's better to have that than to discover the hard way that you purchased the wrong one. P.S., "And don't call me Sureley" LOL (a line from Airplane, the movie...for the un-initiated). |
#9 |
Couple of points:
1. The spinning adapters are not necc heavier than vibrating ones. The Letus Extreme is pretty heavy for example but the Brevis another vibrator is quite light. I prefer a spinner if you can afford it not only because you can use higher f stops, but also because you don't have to worry about dust on the screen being seen on the image. Dust will appear as a smudge on a vibrating adapter. I haven't had problems with my Letus, but it was more problematic with my Brevis though people have had problems with both. The Brevis has changeable screens but I found the problems of getting dust on the screen when changing them a gigantic pain. The standard Brevis screen was until recently the fastest but that may be changing with new additions from SGBlade and the new Redrock Encore. One other difference is field of view. The SGBlade or Pro will only show you the acadamy (cine) 35mm format or something like it. The letus , Brevis and perhaps the new Redrock will show full 35mm frame. There are really very many pros and cons of these things though so you are wise to shop carefully. Anything you hear about the Blade BTW is based on guesswork because they are only being shipped this week. That said I expect it to be a very fine unit. Similarely the Redrock Encore has also just begun shipping so there are no reports form users yet. Lenny Levy |
#10 | ||
I agree with your assesment of spinning vs. vibrating GG. By the way, Brevis says theirs oscillates in a circular pattern as opposed to simply vibrating.
Academy (cine 35mm) is only 24x18mm Full Frame (still camera 35mm) is 36X24mm Quote:
My SGBlade is on the way and I hope to contribute to the test footage posted very soon. |
#11 |
That's great news about the Blade - thanks I wasn't aware of that.
I am actually a BETA tester of the Blade, but my initial unit had oil on the screen and had to be sent back so i eagerly await the next one. I hope that's correct on the image size because it is my only reservation on the Blade - assuming that it will work well with the Ex-1 for which i have my fingers crossed. - Lenny |
