A Fantastic ND filter!
I've been using this filter with my ex1/letus extreme and now can't live without it!
Just thought I'd share..... Singh-Ray Filters: Vari-ND Variable Neutral Density Filter |
looks like two polarizers mounted together.
the problem is this kind of setup will act as polarizer too.... |
so...
So you are using this filter between the camera and the letus extreme?
or you have a diferent filter for each of your 35 mm lenses? or you have ring adapters? Thanks for the info H |
72mm and 77mm on the end of my canon ef lens' ( 35mm f1.4, 17-40, 24-105 ) ..... no aperture control with ef's so this filter has made life easier.
#5 |
Christopher,
Glad you have tried the filter, I've been speculating about its use on these forums for a while. Do you find it has any polarizing effect? What's the widest lens you can use on it without cutoff? Dan |
