Brevis adapter with Redrock support rods
So, I just placed an order on Wednesday for a bunch of new gear, one of the items being a Brevis adapter. However my budget was so tight that I couldn't afford the rails that Cinevate offers at the time. So I (being the "genius" that I am) went to Redrock's store and ordered there support rods without even checking to see if they'd work with the Brevis. Has anybody ever done this before? Should they work or am I going to have any issues connecting the Brevis to them? Thanks for your help!
Andrew
The Redrock rods should work fine - you will want to make sure you ordered the baseplate with high riser for a flip version, low riser for non-flip version. All redrock products are based on standards, including our rods (15mm lightweight standard) Cheers Brian
========================== Brian Valente Redrock Microsystems |
Andrew, if all else fails, our Proteus base (in our update section) will go onto the RRM 15mm rails. We've sneaked our shoulder mount into the design...pad coming this week :-)
