Which adapters for detachable lens camera? at DVinfo.net
Alternative Imaging Methods
Old June 12th, 2008, 11:26 AM   #1
Sorry if this has been answered previously, if it did, I couldn't find it...
Anyway:
If you have a JVC 110 with detachable lens, I know Letus is coming up with a relay add-on to their Extreme adapter to bypass the need of using the stock lens, and I know JVC themselves make an adapter for P-mount lenses (but does not affect DOF), but what about Redrock Micro, Brevis, or some other company?
What other options do I have?
The whole point of buying a detachable lens camera is to detach the lens and I really do not want to use it in conjunction with a DOF adapter.
Any help would be appreciated...
Brian Mills is offline   Reply With Quote
Old June 12th, 2008, 12:51 PM   #2
I think that Brevis is very near to achive what you need. Try to contact Denis to see where he is with his relay for 2/3 cameras. Maybe this will help you too.
Igor Babic is offline   Reply With Quote
Old June 12th, 2008, 10:47 PM   #3
Thanks, Igor, I'll keep an eye on the Brevis. Is it only for 2/3" or will it work with 1/3" cameras?
Does anyone know if there are announced adapters from Redrock Micro, SG-Pro, or anyone else that can work without the camera lens itself?
Old June 13th, 2008, 03:10 PM   #4
Correct, there will be a B4 adapter (mulit-format) designed to work with our current "flipped" Brevis rig. Porting to 1/3" and 1/2" Sony amounts is in the works right after introduction. We've got a few HPX500 users using this setup right now, but of course using a stock B4 lens as a relay.
Dennis Wood is offline   Reply With Quote
Old June 13th, 2008, 08:57 PM   #5
Letus was suppose to be making a relay lens for the XL2 but that effort seems to have been shelved.
Eric Brown is offline   Reply With Quote
Old June 23rd, 2008, 06:48 PM   #6
Determine the focal length needed to zoom into any ground glass with the camera's stock lens.
Then, find a stout SLR lens of a similar focal length. The SLR lens becomes the relay lens. The only issue is attaching it to the video camera and compensating for back focal length.
The only problem with this is that the lens wont be as fast as a custom made one.
See my other post on this forum page for an example of this.
~Justine
"We are the music makers, and we are the dreamers of dreams" -Arthur O'Shaunessey (as quoted by Willy Wonka)
Justine Haupt is offline   Reply
