35mm dof adapter, focusing question. at DVinfo.net
Alternative Imaging Methods
Old May 20th, 2008, 01:52 PM   #1
I was wondering, since I never had searched about a 35mm dof adapter, if the camcorder loses its autofocus? (I mean, when I install a 35 dof like brevis, do I have to use manual focus?)
Thanks.
Fellipe de Paula is offline   Reply With Quote
Old May 20th, 2008, 08:31 PM   #2
using a 35mm adapter will definitely prevent you from being able to use autofocus. you focus on your subject using whatever manual 35mm lens you have mounted on the adapter.
Noah Yuan-Vogel is offline   Reply
