Thread Tools
Search this Thread
Got the Letus Extreme: first impressions
Just got the LEX for my EX1. First thing I noticed: achromat glass slightly chipped off; lucklily out of view (I hope so, didn't check properly yet due to lack of time). Secondly: the GG rectagle not level when mounted on rails and fixed to the camera (twisted some 5-10deg). Again - hopefully, can be adjusted.
But what's most disappointing is the noise of the GG spinning! Do all make so much noise? Frankly, recording sound with on-board mic is impossible! Or is mine defective? Comments welcome
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
Hey Piotr,
Coincidence has it that mine just arrived via Fed Ex today too... Have only quickly opened the box to make sure it was all there... Will have a closer look tomorrow... |
#3 | |
The noise can be helped a bit by making sure everything is really tight. Especially the Letus bracket screws loosen easily (I got new hex screws from letus) and this creates a vibration that the mic picks up. I can't see a way to use the onboard mic for serious work in the original configuration. I will do a little soundproofing out of leather for the LEX when I need to use the onboard mic. The gg is easily adjustable to level with EX1. You can first adjust it with the camera and then if need be adjust the "nose" of Letus to fit the bracket screw. Sami |
Thanks Sami,
I have re-tightened all he screws; the noise has changed pitch, but still everyting is vibrating - the adapter, rails, and the camera! Regarding twist adjustment: not sure if I follow you. If I turn the adpater on the camera to make the GG level, the "nose" won't fit the bracket on rails (the "nose" has 4 screws, but they go into holes on the main adapter body - so the two parts cannot be rotated in relation to each other).
#6 | |
#7 |
Sami, could you elaborate on your idea?
#8 |
To avoid vibration you can use thin layer of leather to put between the letus bracket and the letus nose. You could even put a very thin rubber band (the kind they use on plumbing) between the thread ring and the Letus.
Now for the actual sound from the spinning gg best would be if you could line the inside of the nose with proper acoustic bending rubber (I dont know the proper name but we used this on 35mm cameras mattebox when I was doing sound engineering on a few films). I dont know if there is enough room and it would have to be glued on the nose and thats a bit scary thing to do incase it comes off and hits the vibrating gg. Then you can make a garment for the whole Letus as well from some good acoustic material. Leather-rubber-leather layered stuff might work well. Sami |
#9 |
Moved from EX1 to Letus.
