Canon H1 P+S mini35 and Zeiss 100mm lens at DVinfo.net
Alternative Imaging Methods
Old March 2nd, 2008, 04:09 PM   #1
A quick test with Canon H1 P+S mini35 and Zeiss 100mm lens
http://olegkalyan.ru/_Quicktime/Svet...1000562web.mov
Oleg Kalyan is offline   Reply With Quote
Old March 2nd, 2008, 04:15 PM   #2
LINK's CHANGED
for some reason the link I gave wouldn't play, I could copy'paste it it it worked, some kind of mystery!
Anyway a new one, let me know what you think!
http://olegkalyan.ru/_Quicktime/SvetaKirill_test.mov
would love to hear some comments, 67 views, no response?
Or maybe it's not enough material to make any conclusions?
BTW it was a 300 series!
Old December 31st, 2008, 01:13 PM   #3
Hello,
Looks as if the mini35 gets the job done as depth of field was quite distinguishable; doesn't appear to be issues with the image quality or excessive noise. I'm assuming the clips featured in this video had not been color corrected; the shots seemed to be inconsistent in terms of exposure and color balance. I think it would help to see the result of the final cut, but it seems as if you'll have solid source material to work with for the edit.
The size of the download was too large for review and I suspect that many viewers gave up downloading the file. I would suggest using a smaller frame (640x360) and data size (no more than 800kbps) to achieve a faster viewing experience.
Thank you for sharing and have a happy new year,
Cale
Cale (CJ) Rogers
http://homepage.mac.com/vlcjrogers
Cale Rogers is offline   Reply With Quote
Old January 13th, 2009, 02:49 AM   #4
Looked like some pretty useable footage, I'd agree with Cale about the color balance. It would be interesting to see some other shots, wide shots, exteriors etc as each of the shots you had was very similar.
Lastly, it might be worth uploading your footage to Vimeo? The 44meg size of your file made it a bit of a wait before it could be viewed.
Good work though, look forward to seeing your next test.
John Lewis is offline   Reply
