Questions about Canon EF lenses at DVinfo.net
Alternative Imaging Methods
Old February 16th, 2008, 09:08 PM   #1
Hello,
I see a lot of talk about needing to put Canon EF lenses on a still body to change the aperature.
I would like to ask if somebody can give me a definitive answer if this really works?
I use Canon DSLRs and would like to be able to use the same high end primes on both my video (Letus) and still cameras (5D & 30d).
Buying a used still body just for this task is no problem if it means I can use the lenses on all of my cameras.
Old February 18th, 2008, 05:38 PM   #2
I e-mailed Letus and they said this could be done by removing the lens while the camera is on to keep the iris set.
Nice to know for sure before buying.
Old April 15th, 2008, 10:43 PM   #3
Hey Tim,
Do you mean that the DSLR camera needs to remain on while you take off the lens ?
Does this expose any risks of damage to your DSLR ?
Mark
Mark Wisniowski
www.probe3.com
Mark Wisniowski is offline   Reply With Quote
Old April 30th, 2008, 09:35 AM   #4
Hey Mark,
I just found this post.
Taking a lens off while the camera being on will not hurt the camera, but it might induce more dust to collect on the sensor as the charged sensor has some static effect.
If I go with Canon lenses, I will probably buy a cheap body off of Ebay just to change the lens aperature for the Letus.
This would be worth it for me to be able to use the nice glass on my stills as well.
Tim Polster is offline   Reply
