Canon EF Lenses with Extreme 24, 35, 50, 85 at DVinfo.net
Alternative Imaging Methods
Old February 3rd, 2008, 08:48 PM   #1
Sorry for yet another lens query but after a reading and looking around for about 30 minutes, I still could not determine if the Canon EF lenses would be a good fit with our LEX setups. Looking at:
24mm 1.4L USM
35mm 1.4L USM
50mm 1.4 USM
85mm 1.2L II USM
They will have to be mounted on a still camera to set the aperture? Will there be a problem using a follow focus (focus direction, sourcing rings, etc.). Any other concerns?
I borrowed the 50mm & 85mm from a friend, did a 1/2 day of shooting and it was stunning to see the results. But maybe for the money I'd be better going with a different set?
Many thanks in advance, I hope others that do a search on these lenses can use the results as well.
Billy Mead is offline   Reply With Quote
Old February 3rd, 2008, 11:18 PM   #2
i think setting the aperture on digital still is the only downfall using an EF lens, however if that does not bother you, by all means show the world what the EF lens and your talented skills can do. follow focus does not have bad affects on those lenses.
Willis Chung is offline   Reply With Quote
Old February 4th, 2008, 09:05 PM   #3
Thanks Willis... I have been reading a little more today and found other lenses that might be a little more common for the application. But the Canon's sure looked great.
And we'll see about the 'talent' side but it'll be a fun spring as the weather gets nice here in Boston!
Old February 5th, 2008, 06:12 AM   #4
have fun, i just got the EF Lens mount for my letus extreme
Old February 5th, 2008, 11:23 AM   #5
EF 85mm f1.2 will not work on DOF adapters!
Be aware that the mighty Canon 85mm f1.2 EF lens can not be used without power from the camera as it has electro-mechanical manual focusing ring that does not work without the EOS camera body. I have the EF 85mm f1.2 MKI for still photography and it doesn`t focus manually on DOF adapters.
Therefore I got a FD version of this lens as well as some other rare puppies from the higher end of Canon FD series. Also hopefully the Letus FD mount will be of the best quality without any play in it. Unfortunately good glass never comes cheap even if discontinued for almost 20 years like the FD ones.
Cheers,
T
Toenis Liivamaegi is offline   Reply With Quote
Old February 5th, 2008, 02:19 PM   #6
Toenis, you are so correct. The 85mm ring will just spin and spin, but no focus!
Do you care to share with me the your hints for 'rare puppies' for the FD mount? :)
Old February 6th, 2008, 04:38 AM   #7
i got an EF mount, doesn't mean i will be using EF lens =P
Old February 6th, 2008, 09:21 AM   #8
Not so rare but still not so common are the 14mm f2.8 L, the TS 35mm 2.8 and of course the 85mm f1.2 L as I tend to believe that the 24mm f2 and 50mm f1.4 are quite common. All of those are of the newest series of FD.
Cheers,
T
