DIY 35mm adaptor- covering holes at DVinfo.net
Alternative Imaging Methods
Old October 18th, 2007, 07:22 AM   #1
Hi everyone,
I have been busy making my own 35mm adaptor pretty much based on the one from Wayne Kinney: Sgpro.
I have noticed that many adaptors are 100% sealed so that no dust can get inside. My issue being that when I remove the SLR lens I can see inside and dust can get in.
So what have you guys used or suggest I should put to cover the holes. Adding an extra bit of glass would I beleive make me loose light. Plastic but what type of plastic!
Any suggestions?
Simon Heymans
http://www.vimeo.com/simonheymans
Simon Heymans is offline   Reply With Quote
Old October 18th, 2007, 08:33 AM   #2
Simon,
Try the glass of uv filters. actually i left mine open.
just made covers for the holes for stowage and when i travel. The spinning motion when the adapter is turned on will "shrug" off any debris, if any, on the GG.
Old October 18th, 2007, 09:52 AM   #3
Brevis is sealed from both sides with multicoated plastic UV filters. Hope this helps.
Igor Babic is offline   Reply With Quote
Old October 18th, 2007, 11:03 AM   #4
Images: 1
I believe they are glass. But yes, just apply UV filters to either side of your GG contraption to prevent dust from entering. Although with spinning designs it is less of an issue.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old October 18th, 2007, 11:50 AM   #5
Letus35a has a glass protecting front side of GG screen, however, I broken it trying to clean dust off ground glass one day, and never replaced it.
I agree that dust is more of a problem with vibration adapters, than with spinners, and my self built spinner doesn't have anything .
Chris J. Barcellos
