Microphone mountable sound barrier ? at DVinfo.net
All Things Audio
Old June 28th, 2007, 03:58 AM   #1
I mean stand mountable (edited later)
I'm looking at a low-profile device that will absorb room reflections around a microphone. I remember reading in "Electronic Musician" about two of those products that are U-shaped and can be mounted on the microphone stand to absorb unwanted room reflections. They were in the $200-300 range, I think. I just can't even come up with search terms that work. I've seen some nice "voice box" DIY kits with Auralex, but I'm looking for a portable solution.
Thanks !
Gints Klimanis is offline   Reply With Quote
Old June 28th, 2007, 09:10 AM   #2
You're not thinking of parabolic reflectors, are you?:
http://www.mineroff.com/nature/parabolic.htm
Not really to absorb unwanted room reflections, rather to focus the wanted signal onto the microphone capsule.
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline   Reply With Quote
Old June 28th, 2007, 10:56 AM   #3
That's good to know. The device I'm looking for has several layers of sound absorptive material and is an extruded U or V shape. Gotta find it.
Old June 28th, 2007, 03:06 PM   #4
Hi
You probably mean the reflektion damping shields for microphones. They are made by SE Electronics, and they are quite usefull. I have use one for voiceovers. Not as good as a booth, but very flexible. Take a look at:
http://www.seelectronics.com/rf.html
Rgds
JOSS
12c41
JOS. Svendsen
Jos Svendsen is offline   Reply With Quote
Old June 28th, 2007, 03:44 PM   #5
I've got one of those SE units. Works well and sure as heck looks impressive.
Don't try to use it on a typical mic stand though, it is quite heavy so we mount ours on a light stand which works very well.
Old June 28th, 2007, 06:16 PM   #6
I'd opt for a better mic with a tighter pattern first.
Regards,
Ty Ford
Old June 28th, 2007, 08:46 PM   #7
Originally Posted by Jos Svendsen View Post
Yes, that's it ! Many thanks for the link. Also, I saw a competitor's product in either Electronic Musician or DV mag with a larger barrier for about $100 less. Gotta find that one, too.
Old June 29th, 2007, 07:12 AM   #8
Looks like the product works by absorbing high frequencies and diffusing some of the upper mids at the source in a close mic situation. Just curious, what is your application for this product?
Jim Boda is offline   Reply With Quote
Old June 29th, 2007, 08:45 AM   #9
Ethan Winer has done some interesting tests using the SE Reflexion filter and his own product....finding the SE product colors the sound. check out his site at http://www.realtraps.com/p_pvb.htm
Bill Mecca is offline   Reply With Quote
Old June 29th, 2007, 01:28 PM   #10
The RealTrap is the other product. Cool.
Anyway, my application is just to have an unobstrusive, portable sound barrier that I wouldn't hesitate to pack in the car for road trips. Given the rave review I remember reading in Electronic Musician, I'd like to find out if these products are better (both in absorption and coloration) than an open sound box I could construct with cardboard/plywood and Auralex or money spent on microphones with tighter pickup patterns. In any case, I'd like something that would attenuate low frequencies from highway noises as often, I don't have time to alter the recording environment or opportunity to choose a better location.
