rode nt-3 outside at DVinfo.net
All Things Audio
Old June 9th, 2007, 06:52 AM   #1
rode nt-3 outside
i have an outdoor interview and the shotgun mic is busted. if i use a rode nt-3 on a short mic pole with a windscreen, will i get any usable audio or is the nt-3 just not useful at all outdoors?
Mike Donovan is offline   Reply With Quote
Old June 9th, 2007, 07:22 AM   #2
Not replying based on direct experience with it but I'd suspect it'll be fine if you're careful. Two issues to deal with - I understand it's quite sensitive to wind currents so good windscreening and staying in the lee side of buildings etc if possible will be something to keep on top of, and it's pretty heavy hanging out there on the end of a pole so take pity on your boom op and put it on a mic stand with a boom arm if possible.
Old June 9th, 2007, 02:46 PM   #3
find a well protected spot (from wind and noise) use a windmuff and monitor your recording and it should be good. The Nt3 is an amazing mic but quite sensitive. Do some test with the mic att on.
Robert Morane is offline   Reply With Quote
Old June 9th, 2007, 03:14 PM   #4
Images: 32
The A81WS Large Foam Windscreen is a decent inexpensive option for the NT3. Make sure to pull it over the on/off switch, that area seems to create a lot of wind noise. It's a very snug fit.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply
