ME66, internal battery, 12 or 48V? at DVinfo.net
All Things Audio
Old May 11th, 2003, 10:49 AM   #1
The MM-1 preamp can supply phantom power from its two AA batteries.
It can supply either 12V or 48V with 10mA (I can imagine that using the 48V would impact the battery life).
I'm interested by removing the AA battery of the ME66 power module (another battery not to think about). So I have the choice between 12V and 48V.
What would you suggest ? Or should I stay with the internal battery ?
Dany
Dany Nativel is offline   Reply With Quote
Old May 11th, 2003, 11:07 AM   #2
Warden
Generally speaking you get slightly higher performance from the higher voltage. However, that slight performance advantage would be lost if you're recording to mini DV. If it were DAT, that would be a different case.
Jeff Donald
Carpe Diem
Old May 11th, 2003, 03:34 PM   #3
Jeff,
Why would it be a "different case"? Both can record 16bit, 48kHz. What are the advantages/disadvantages of one compared to the other?
Bruce Findleton
Land's End Productions
Pleasanton, CA
http://www.landsendproductions.com
Bruce Findleton is offline   Reply With Quote
Old May 11th, 2003, 03:41 PM   #4
DAT and MD can record Line levels but GL2 only Mic levels but from what I've heard it shouldn't make a difference.
Old May 11th, 2003, 04:50 PM   #5
Warden
A few DAT recorders do 24bit sound. But even the 16bit recorders have higher S/N ratio and dynamic range than DV. DV audio is PCM, but the implementation of it by the camera manufactures results in lower quality audio recording. After all a portable DAT recorder is more expensive than most of the mini DV cameras on the market.
Jeff Donald
Carpe Diem
Old May 11th, 2003, 08:49 PM   #6
How would you rate a Sony TCD-D7 or D8 DAT prosumer recorder compared to the miniDV ?
Old May 12th, 2003, 10:17 AM   #7
Warden
Just about any DAT recorder will out perform a mini DV camera in my opinion. However, how you tweak the audio after acquisition has a great deal to do with your final output. Any project that requires superb audio, I take my original audio files to a recording studio for sweetening.
Today, I think the DVX100 has one of the best audio sections in a mini DV camera, I've heard. The XL1S would be second.
Jeff Donald
Carpe Diem
Old May 30th, 2003, 10:30 PM   #8
Just got my MM-1 .... beautiful !
I made some tests and found out that powering the mike using the internal battery of the ME66 generated more noise thant using the 12V from MM-1. Anyway I wanted to used the Phantom from the MM-1 so I don't need to monitor the ME-66's battery !
