beachtek dxa-10 battery duration at DVinfo.net
All Things Audio
Old April 14th, 2007, 08:37 PM   #1
Typically, how long does a 9 volt battery last in beachtek dxa-10 with 2 mics connected using phantom power for both mics?
I'm getting terrible results making this device useless.
Does anyone use this preamp with 2 phantom mics successfully?
Richard Zlamany is offline   Reply With Quote
Old April 15th, 2007, 02:41 AM   #2
Terrible results as in short battery life or terrible results as in bad sound?
Old April 15th, 2007, 05:26 AM   #3
My DX8A will only last about 3-4 hours on a battery doing two mics with phantom voltage before the battery drops to around 8v. When it gets below 8v, I start getting distortion. When doing a continous shoot, I replace the battery on the third tape just to be sure.
George Ellis is offline   Reply With Quote
Old April 15th, 2007, 10:41 AM   #4
Yes, short battery life. A brand new battery died in 1 hour using 2 phantom powered mics, so after testing and setup time, I only recorded about 20 minutes of a 2 hour show.
The 1st 20 minutes sounded great.
How could I possibly use this device for any serious work if the record time is so short? I bought this device specifically to power the phantom powered mics. I can't plug the device into anything because it only takes one 9 volt battery, so it is basically useless to me.
The entire thing is a disaster.
Old April 15th, 2007, 12:38 PM   #5
That does seem short. Sure the battery was fresh to start with and that you used an long-life alkaline or lithium cell instead of a vanilla carbon battery? Is there an external power jack so you can rig up an external battery pack of some sort to power it so you can do a quick change between takes? (Don't know what you mean when you say you can't plug it into anything cause it only takes one battery.)
Old April 15th, 2007, 12:58 PM   #6
It was a new duracell battery. I just ran a test with another new Duracell battery and the preamp lasted for 80 minutes. The battery came out hot and dead.
I'll try a lithium 9 volt battery and see what the results are.
What I mean is it would be nice if I could just plug the preamp into the wall and not have to worry about batteries.
On the spec sheet it say the dxa-10 lasts for 4 hours without phantom power. It mentions nothing about the lasting time with phantom power.
Can you recommend a battery?
Would this work?
http://www.homedepot.com/prel80/HDUS...ct-_-100001883
Perhaps this would be better and more suited:
http://www.bhphotovideo.com/bnh/cont...goryNavigation
Old April 29th, 2007, 08:47 PM   #7
Well I used the Home Depot Energizer Lithium battery. It passed with flying colors and lasted 3 hrs with time to spare.
If I had only knew earlier.
