Underwater Sound Effect at DVinfo.net
All Things Audio
Old April 5th, 2007, 09:32 AM   #1
Can someone recommend either a plug-in or audio workflow to achieve an underwater sound effect?
Specifically, I am going to apply it to a boat engine sound.
Thanks in advance,
Brian
Preview of "CATCH A RISING BULLET"
http://films.thelot.com/films/34064
Short Film "Lipstick & Lithium"
http://films.thelot.com/films/23105
Brian Mitchell Warshawsky is offline   Reply With Quote
Old April 5th, 2007, 09:41 AM   #2
Get an aquarium.
Put a speaker next to it.
Put a microphone in a condom
Put it inside the aquarium, you'll need BB shot to help hold it down.
Put a CD of engine noises in your CD player and play it out to the speaker.
Move the water around.
Presto~ underwater sounds.
Or you can spend a lot of time twiddling EQ, chorus, flange, phase, compression. :-)
There is an old book on sound design, can't recall the name. They went through the same things we did when working on a submarine film; they tried to create the sound design in a studio, and found it worked better to go to the local swimming pool, and also to use large aquariums. YMMV
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 5th, 2007, 09:45 AM   #3
Spot,
You always come through with the answer.
In my entire film, this will amount to all of five seconds, but I think I'll do it anyway.
Thanks again!
Brian
Old April 5th, 2007, 09:47 AM   #4
Don't forget to include the "PING" "PING" of sonar sweeps. Everybody knows they're always present in any underwater environment, even swimming pools, heck, even bathtubs!
<Couldn't resist!>
Old April 13th, 2007, 05:01 PM   #5
More importantly, don't forget to notify the wife before she sees any condoms lying around.
Generally the underwater sounds you hear on TV are effects emulating scuba. The sonar ping is classic, but unless you are editing Crimson Tide 2, it might be a little over the top.
As a side note, I accidentally left my mic recording sitting right next to a noisy computer once, and when I got it in my audio app, I didn't remember what it was. After playing it many times, I finally remembered and played with the EQ's and dropped the lows... it sounds just like you have water in your ears from a swimming pool. I'm still waiting for when I use that one.
Deke Ryland is offline   Reply With Quote
Old April 13th, 2007, 07:43 PM   #6
Or use a recording of an engine idling, slow it way down, and play with damping points in the EQ to get that somewhat muffled, not quite present underwater thing.
Mark OConnell is offline   Reply
