Location: Oxford, UK (until 2008: Lhasa, Tibetan Autonomous Region)
Sound Devices 7xx as Mixer?
Is there anything that would prevent a Sound Devices 7xx recorder to double as mixer? I have to plan for minimal weight for my next project. A recorder is a must and I have to buy a new one anyway. But there will be many instances where I would rather need a mixer instead of a recorder. When I look at the SD 7xx specs (pre?amps, limiter, high?pass filter, tone, good metering, line out, phantom, individual knobs for gain control, etc.) I feel it should serve as a good mixer as well.
Opinions? Martin |
Well, a recorder really doesn't make a good replacement for a mixer. Taking the 744T as an example (since that's the one I'm most familiar with). You lose a lot of fast control over your audio since most of those features that you mention (limiters, high-pass filtering, phantom power, etc.) are buried in the menu system rather than available at your finger-tips. It only provides two channels of pre-amps (the other two are line level). There isn't an easy way to fade between output channels. There isn't fine control over how channels 3&4 reach the output. The outputs are TA3 connectors instead of XLR. It is a huge power hog for a mixer. All-in-all, it's a outstanding recorder, but not a great mixer.
I don't want to sound too discouraging. The 7 series recorders are great pieces of equipment. If all you want to do is record a couple of channels of audio, then it may be all you need. I often just use the recorder when doing field recording of voice overs, interviews, or sound effects. Couple a 744 with a MixPre, and you have 4 tracks of very high quality audio in a really tiny package. If, however, you are expecting the recorder to work well as a mixer, then you may be disappointed. |
#3 | |
I have a 744T and a 442. I would not want to mix with the 744T. I would not want to record with a 442. Regards, Ty Ford |
