on camera 3.5 Vs. minidisc at DVinfo.net
All Things Audio
Old March 12th, 2007, 01:34 PM   #1
I'm contemplating purchasing a much better mic, like the AT 4073 and a preamp like the sound devices mixpre. The camera I'll be using will be a pana AG-DVC7, which only supplies 3.5mm mini audio input, hence the mixpre.
Obviously some of the quality from the higher grade mic and preamp will be lost when recording in camera, but will that loss be significant enough not to bother with recording to camera, and instead purchasing a seperate recording device, like a minidisc?
I don't have the budget for a recorder with XLR inputs, so my question really is, will a minidisc be that much superior to recording in camera?
I understand there are microphones that do not require phantom power, and adapters to feed XLR to 3.5, but I'm plannning to start investing in high quality audio gear now, and fill in the holes later, AKA maybe an SD 702 CF recorder... eventually.
-Alex
Alex Milne is offline   Reply With Quote
Old March 12th, 2007, 02:20 PM   #2
Whether you decide to record in camera or on an external recorder there are a couple of things to keep in mind. The SD MixPre has your choice of outputs - either pro line level output on a pair of balanced XLR connections or consumer line level on an unbalanced stereo 3.5mm minijack. But your camera only has a mic level input and although the connections are right to plug directly from the MixPre's 3.5mm output, the level will be way too hot for the camera and you'll need an attenuating cable or an inline pad to prevent distortion. If you're looking at a minidisk recorder, same thing applies - make sure it has a line level input to plug the MixPre into.
Old March 12th, 2007, 02:47 PM   #3
Steve-
After I had this question answered I was going to post another thread, asking how to manage levels with this setup.
I'm unfamiliar with the two devices you mentioned. I understand what they do but am a little unclear on the specifics. If I want to go from the mixpre's 3.5 out to the camcorder's 3.5 in, what might be some appropriate products to get the job done?
perhaps... http://www.bhphotovideo.com/bnh/cont...ughType=search
Also, why can't I just turn down the gain on the camcorder? Distortion?
Old March 12th, 2007, 03:32 PM   #4
Originally Posted by Alex Milne View Post
Steve-
Yep, you said the magic word - distortion. All audio circuits are designed to work with an optimal incoming signal level - like Goldilocks porridge, not too hot and not too cold. Mic level signals are relatively weak and require a sensitive input to respond to them. Line level signals are many times stronger, so strong that they will readily overload a mic level input and cause clipping distortion before they ever get to the part of the circuit where the gain control resides and has any effect. And just to make things interesting, there are two different standard 'line levels' - professional strength and consumer grade. The pro level is +4dBU, corresponding to 1.228 volts, while the consumer level is -10dBV, corresponding to 0.316 volts. (To compare, 'mic level' ranges from about -35dB down to the vicinity of -55dB depending on type.) The MixPre puts out pro level signals on its XLR ouputs and consumer level signals on its 3.5mm Tape Out connector. But even the consumer level output is going to be too hot for a mic level input. The solution is to insert an attennuator or 'pad' to reduce the line level down to the right match for a mic input - they are very common for XLR cables but less so for 3.5mm cables, especially 3.5 mm stereo cables. You might have to make your own or go with something like a Beachtek adapter between your MixPre and the camera. Something like the one in the link is a step in the right direction but I don't think 10dB will be enough.
Old March 12th, 2007, 04:33 PM   #5
Alright, well looks like this isn't going to work out, since time is of the essence.
I think I'll just pick up an ME66. There's no reason I'd need a pad to run directly from the mic (running off AA) to an adapter directly into the camera, right?
Hopefully the resale is good on the ME66, so I can dump it afterwards.
Thanks-
-Alex
P.S. Hypothetically, could I output from the mix pre on the left XLR (I think left) channel to get a mono signal, then use an XLR pad, and then a 3.5 adapter to get to the camera, or would this just be a waste of cable?
On that note, is there any reason why I can't stack them? AKA, three -10db = -30db?
Old March 12th, 2007, 05:09 PM   #6
It would depend on your adapter and your subject matter. The K6/ME66 is a very high-output mic and would probably need some attenuation when adapted to the mini mic input. A BeachTek-type adapter will do this with the attenuation controls, a regular adapter cable won't but you could combine an attenuator with an adapter. AT and Shure make switchable in-line attenuators.
You could attenuate the XLR output of a MixPre, but you'd need 50 to 60 db of attenuation to bring it down to typical mic level. A BeachTek-type adapter can do this with the Mic/Line switch.
There are less expensive battery-powered mid-output mics available that might sound better and not require attenuation. It depends on how, where and what you're recording.
Jay Massengill is offline   Reply With Quote
Old March 14th, 2007, 05:36 AM   #7
You might consider the Sennheiser MKE 300 Video mic (http://www.sennheiser.com/sennheiser...sf/root/03171). It has a 3.5mm connector so you don't have to deal with adapters. I haven't used one in a long time, but I recall it sounding as good as the ME series.
Best wishes,
Peter
______________________
http://www.parkfilms.com
Peter Rhalter is offline   Reply
