Setting up PPM meter at DVinfo.net
All Things Audio
Old February 26th, 2007, 04:54 AM   #1
Hi there i have an edius 2.5 with storm 2 editing set up. I have recently added the beguelle ppm meter to my setup, which i have seen work excelently at a tv company.
www.belleguelle.net free 1 month trial if anyone wants it.
There is some advice given for setting up, and what is needed is a test tone of a known recomended ppm so i can calibrate it. I cant find any option in edius to do this, any suggestions?
StMichael
Michael Connor is offline   Reply With Quote
Old February 26th, 2007, 05:51 AM   #2
I can create tones in Sound Forge, what frequency, level (relative to 0dBFS) and duration do you need. Any specific bit depth and sample rate? I'm guessing 16/48K to match DV.
Might be big files so I could email them to you.
Old February 26th, 2007, 06:16 AM   #3
48k rings a bell, just lookin through settings, cant find. Am using pal, is that what austrailia uses too?
Cant remember what the norm is, think it was 6 ppm the test tone was set at at company i used to work for.
Thankyou. My email adress is ihadaeureka@hotmail.com
StMichael
Old February 26th, 2007, 08:42 AM   #4
Images: 10
PPMeter, available from Raw Material Software, comes with a built in calibration test tone. They have a free trial available. You might want to check it out.
Old February 26th, 2007, 10:01 AM   #5
The bitrate/sample rate don't matter for purposes of calibration, it's level and frequency.
There is a package of free tones available.
You do have to register to download them.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old February 26th, 2007, 10:18 AM   #6
Looking up my old BBC notes - 1k Hz tone at 0.775 volts into 600 ohms is the reference level for mono - lined up on "4" on the PPM.
Brian Drysdale is offline   Reply
