Audio Meter says ok, but clipping is still happening? - Page 4 at DVinfo.net
All Things Audio
Old March 8th, 2007, 09:50 AM   #46
Which is, BTW, precisely why you want a mixer with a VERY GOOD sounding limiter;
so you can record hot without fear of overs. Also be advised that not all computer systems treat internal audio busses the same.
Some folks have "normalized" all tracks to within a half a DB of clipping only to find that things sound a bit grainey during the mix. They don't realize that the internal buss has to combine all of thse VERY LOUD tracks and may, at some point, not be able to handle that much combined level.
Keeping it real in audio,
Ty Ford
Old March 8th, 2007, 09:59 AM   #47
Images: 10
EXACTLY why I think 24 bit(192kHz) recording beats the pants off of 16 bit recorders.
Old March 8th, 2007, 10:16 AM   #48
Ty brings up another excellent point, many folks start with normalizing. Big mistake, IMO. Are they normalizing RMS and not peak? Are they normalizing to reduce dynamic range or bring the audio to a louder point? It can create serious havoc once you start mixing if you don't know why you're normalizing beyond "I heard it was good to do."
We don't normalize here; it's the first thing new editors are taught. Leave the levels alone, unless you have reason to believe it wasn't acquired correctly.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 8th, 2007, 10:22 AM   #49
Images: 10
Just my opinion, but, "normalizing" is a useless and destructive process. If done at all, it's done at the mastering stage, after the mix has been finished. Even then, normalizing can be done at the RMS level, provided that the peaks are compressed at some level below 0dBFS and not clipped. But, if compression has been applied during mastering, there's not much point in a further compression step.
Old March 8th, 2007, 11:17 AM   #50
It is a pleasure to read the contributions from pros like Spot, Ty and Bill. Thank you gentlemen for contributing your decades of experience in a public forum. Readers, in case you are missing it, this is the real stuff.
Originally Posted by Zulkifli Yusof View Post
...Audio mismatch. I understood this completely since I had a very bad personal experience with it before. The problem could be because the microphone output to the recorder was too hot, a case of a bad cable, improper audio connections, or the recording gain setting was too low/too high.
Usually this is preventive as long as you pay attention to your cans and the levels of the recording. During monitoring, headphones should not be giving out its own distortions. If it does, either tone down the listening level or get a better pair of cans.
So am I right to say that you are monitoring the analog signal thus analog clipping (in your headphones; not the levels) are soft transient distortions which are fine, digital clipping is unintelligible and unusable?...
Zulkifli, you are on the right track, and have somewhat answered your own question on gain structure. Here are the basics. Overload can occur at any stage. The mic diaphram, the (condensor) mic preamp, the input stage of the mixer, the output stage of the mixer, the input stage of the camera or recorder, etc.
Analog distortion in the modern production chain is not acceptable (unless as an intended effect). Digital may be crunchier, but analog is still bad. In ancient times, with an analog magnetic tape recorder we tended to consider hotter peaks to the recording as (analog!) tape was very forgiving of minor overload, and tended to still sound "musical".
Even with those technologies, overloading the mic, preamp, recorder electronics, etc. sounded bad and was avoided.
So, the answer to your question about soft analog transient distortions is: Don't overload at any stage, period. Get to know the sound of your headphones, and monitor everything you can, all the time, with headphones. Monitor (spot check) the camera's headphone output frequently. Listen to tape playback, especially if/when you're unsure.
Old March 8th, 2007, 12:33 PM   #51
Bill,
I understand 24 bits, but I don't understand how 192kHz helps you with this (assuming you'll eventually deliver to, say, 48 kHz). Can you please explain what you meant by this?
Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old March 8th, 2007, 01:11 PM   #52
Originally Posted by Douglas Spotted Eagle View Post
I can count on one hand, the number of projects we've had sent back down due to pushing the required levels by a few dB. New York, Vernon Johns Story, Last Queen, The War that Made America, The Way West...all PBS shows, all Emmy, DuPont, or Peabody winners, and all with pushed audio. There is a difference in acquisition, which is where 99% of videographers screw up due to misunderstood threads like this one, and delivery, which is screwed up also due to misunderstanding the differences between averages and peaks.Acquisition, you want as HOT as possible without exceeding 0. It's common practice, and common sense. Delivery, you can do whatever you need, but at least you've got the bit depth to have anything to do with, what you wish.
Somebody down the chain might be turning it down. Or your shows might be compressed by a Master Limiter when broadcast. It's the Master Controllers job to make sure that your program is no louder than anyone else's. So it's pointless to try to push your levels hotter than others. If you send them a hot master they're going to turn it down. I'd rather send out something I know is not going to be limited when broadcast. You never know how they have their limiters set.
I agree with you about acquisition. Especially since most acquisition formats are 16-bit. Got to maximize that dynamic range. I don't like having a mixer in the chain when I'm shooting by myself, so I tend to be a little conservative with levels. Noise can be cleaned up (especially with dialogue), clipping can't. When I'm recording an interview, I'll record one channel at 3 to 5 db less than another, so if the loud channel clips, I have the quieter one.
Brett Sherman is offline   Reply With Quote
Old March 8th, 2007, 01:23 PM   #53
Now again, we're getting into a different realm. We're pushing peaks based on dynamic range, not pushing the final output. My goal is, and always has been, to shoot for the most wide dynamic I can get away with. Both my partner and I were scoffed at for years for pushing dynamic range, and then one day Walter Murch wrote about how he wrings every tiny bit of amplitude from every relative portion, and bam....we were no longer scoffed at.
Master Controller or not, PBS is by FAR the most difficult broadcast organization that we may submit to. They don't allow a submission to get as far as a master controller turning levels; they simply reject the submission whether it's for audio or video challenges.
My experience has been that there is no give and take with PBS. YMMV, but I'd be surprised.
The Food Channel and Court TV are just the opposite. Give em' anything and they'll ship it downstream.
Old March 8th, 2007, 01:58 PM   #54
I see what you mean. I suppose as long as your averaged level is around -20db, your peaks are probably less of a red flag. I can see pushing to -6db for peaks.
I've only submitted to PBS, so I didn't want to push things too much. Better to have it go through with 4 db less of headroom than to be rejected is my philosophy. Plus, it looks bad for client work if your master gets rejected. But if it was completely self-produced and there's no significant cost to making a new master, I can see pushing the limits.
Old March 8th, 2007, 02:05 PM   #55
Originally Posted by Martin Pauly View Post
Bill,I understand 24 bits, but I don't understand how 192kHz helps you with this (assuming you'll eventually deliver to, say, 48 kHz). Can you please explain what you meant by this?
Some might say 192kHz sounds more accurate or richer than 48khz. But it has absolutely no effect on dynamic range. If you're recording voice, I would seriously question any perceived difference between 192khz and 48khz. Music, maybe there might be some advantage to capturing at a higher frequency then processing (EQing, Compressing) at a higher frequency and only at the end bringing it down to 48khz. Notice I said maybe, I'm not convinced there would be any audible difference and certainly there are more pressing things to worry about in your production.
Old March 8th, 2007, 03:13 PM   #56
Images: 10
you're quite right, Brett....more pressing things all over the place. But, if the capability is there, why not? I suppose that's more the question.
Old March 8th, 2007, 03:48 PM   #57
Disk space, CPU processing overhead, workflow issues. If those things aren't an issue than absolutely go ahead and record 192khz.
Old March 8th, 2007, 04:04 PM   #58
Images: 10
Not much of a problem with any of these. Biggest one is to dither back down. And even that is NBD.
Old March 9th, 2007, 01:51 PM   #59
Don't get me wrong, I can see advantages of 192 kHz over 48 kHz. But if your final mix/product is going to have 48 kHz audio, then I am wondering if there is any advantage of going higher than that earlier in the recording chain. I have the equipment to to that, but never bothered to because I didn't see the point (and, yes, disk space, cpu overhead etc. are real considerations). So I am curious if anyone can convince me otherwise.
Unlike, of course, the choice of 24 bit vs. 16 bit acquisition, where it's a no brainer to go with 24 bits if you can.
- Martin
Martin Pauly
Old March 9th, 2007, 03:50 PM   #60
Not unless or until the playback systems can reproduce the bandwidth recorded at 192 kHz.
There is an argument to be made about Nyquist filters at 19 kHz (for 44.1 and 48 kHz) and the in-band damage they can cause. If you want an argument about it, try rec.audio.opinion.
You won't get one from me.
Regards,
Ty Ford
Ty Ford is offline   Reply
