Better tie clip for Sennheiser G2 system? at DVinfo.net
All Things Audio
Old December 3rd, 2006, 01:35 PM   #1
I've bought a couple of G2 systems, and they've worked great.
The only issue is the supplied microphone clips, which are big and ugly. Only a bit of folded-over Gaffer Tape would outshine its ugliness. The mic its self is fine - just the clip.
Can anyone suggest a commercially available clip that is small and discrete?
Old December 3rd, 2006, 02:40 PM   #2
Look at this Thread:
http://www.dvinfo.net/conf/showthread.php?t=78450
Vincent Rozenberg is offline   Reply With Quote
Old December 3rd, 2006, 02:52 PM   #3
Originally Posted by Vincent Rozenberg
Thanks for the thread, Vince - however, this covers the mic its self, not the clip. Whilst I'm not going to sell off my Cos-11s, I'm very happy with the Senn's G2 mic.
It's the clip. A purely cosmetic thing. ECMs look workmanlike, COS-11s almost invisible and very 'pro'; the G2 mic would look fine IF it wasn't snagged to a slab of cheap plastic clothes-peg.
:D
Old December 4th, 2006, 11:05 AM   #4
B&H sells mic clips for the MKE2 mic that are similar to Sony's ECM77 clips. You could also try some generic vampire clips.
Peter Rummel is offline   Reply With Quote
Old December 5th, 2006, 04:57 AM   #5
Those loops in the cable and those 'clothes-pegs' are there for a good reason. They stop mechanical noise going up the cable into the mic itself. If you use another clip arrangement make certain you have a loop in the cable as close to thi mic as possible to stop noise.
Old December 10th, 2006, 11:11 AM   #6
Search "lav tie clip" on B&H and you'll find lots.
I'd like a quality tie clip for a Tram 50 mic -- any suggestions for that? The vampire clips are good but the tie clip for the Tram is crummy -- the mic falls out of the clip easily. I'd like something like the Audio Technica clips.
Chuck Fadely is offline   Reply With Quote
Old August 18th, 2007, 05:41 PM   #7
I just got a set of Tram lavs for my 2 g2 systems and have the same feelings on the tie clip...crap, especially for such an expensive lav you would think they would have a better mount. In the week I have owned the mics I have spent at least an hour searching for the tie clip after it fell off the mic. Does anyone have a solution to this problem?
Dave Pecunies is offline   Reply With Quote
Old August 19th, 2007, 03:51 AM   #8
How about something like this?
http://www.shure.com/ProAudio/Produc...K354SB_content
The tiny clip grabs the wire of the mic. I use these with Countryman mics as well as my AT lavs.
Dean Sensui
Old August 19th, 2007, 12:49 PM   #9
Thanks for the tip-off! Looks perfect - hope they're available in the UK...
Matt Davis is offline   Reply
