rca line level to heaphone mod? at DVinfo.net
All Things Audio
Old November 23rd, 2006, 09:15 PM   #1
Hi all,
Just wondering.
Got a single chipper here with no headphone jack i want to use as a 2nd cam for a wedding.
Is it possible to convert the rca output line level from socket to headphone level?
with an rca to stereo mini female adapter?
do i need a pre amp?
Brendan Sundry is offline   Reply With Quote
Old November 24th, 2006, 01:57 AM   #2
Most I've seen let you tell the cam in menu to treat it's AV jack as a headphone out - what model cam is it? Steve
Steve Leverich is offline   Reply With Quote
Old November 24th, 2006, 05:17 AM   #3
Steve, its a PAL zr500 the mv920.
Mic input/widecreen. OK for a cutaway cam.
Any other ideas?
Old November 24th, 2006, 02:05 PM   #4
http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900
PDF manual for the zr500 -
I went thru the entire manual and I'm afraid you're correct - this sucks. I have a couple of the Elura series for the same reasons you bought yours, a 65 and a newer 100, and both allow you to reprogram the AV jack to be a headphone out. Also both of mine are top loaders and have mic inputs (as does yours apparently- the mic input, I mean.)
Do you know if your ZR500 puts out line level audio while you're recording? I would hope so - if it does, all I can think to do is look for a small battery-powered amplifier that takes -10 dB in and outputs a headphone level.
Man, if they keep "dumbing down" DV cams for the public, even my wife is gonna want an XL2... Steve
Old November 24th, 2006, 02:24 PM   #5
http://www.boostaroo.com/store_detail.php4?id=1
If you have a Radio Shack available, you should be able to find a couple of adapters - you'll need a stereo mini male/dual RCA female, and a double female stereo mini adapter. Use your AV cable's dual RCA audio into the first adapter, then couple its male mini to the headphone amp's male mini and bob's yer uncle... Steve
Old November 25th, 2006, 06:18 AM   #6
Steve,
Appreciate your efforts.
I actually tried using the mini video/audio out terminal and adapter the audio rca's to accept my headphones and it worked!
I was stoked.
Im pretty damn happy with this cam, i does so much for so little
Also i think it does -10dbfs?
Also there is a thread on the lens for a filter but i cant see any info on the size. The canon website says n/a
Have you had any experience on this?
Old November 26th, 2006, 05:53 AM   #7
Nope; B&H site also says "none" under filter - are you sure those are threads? I ran across another camera a while back that LOOKED like it had threads, turned out they were concentric RINGS instead.
If you're sure they're actual threads (try gently running the tip of a straight pin or needle in the groove, go around at least twice and see if you're any closer to the edge) - if they are indeed threads, take it to a camera shop and see what fits (don't tell 'em you're just looking :=)
One thing - yours has a "lens cover switch" same as my Elura 100 - mine also has threads (I keep a 0.7 WA adapter on it most of the time) but yours may, because of the SWITCH that covers the lens, not offer any threads. Try that check with the needle before you bother moseying on down to the nearest camera shop.
Also - just because your line output lets you hear your headphones, does NOT mean that this is "good" for your cam - its output is -10 dB, true, but that's with a 47kohm load - most headphones are under 600 ohms, some are down around 32 ohms. This could be nearly the same as shorting out your audio output, and may "let the smoke out" of your new friend - when this happens, it's pretty expensive to find someone to "put the smoke back in". In a lot of cases, the cost is the same as buying a new one (because that's what it takes :=)
One last thing - if you look at the front of your lens, usually around the front there will be a bunch of writing - something like "20x zoom 3.0-60mm 1:1.8", this may be followed by a zero with a vertical slash thru it, followed by a number like "27" - if so, this is your filter size in mm.
Good luck... Steve
Old November 27th, 2006, 02:29 AM   #8
Im afraid your right about the threading. They are just rings. And if you look close the rings taper off to become less than a perfect circle.
So imm still looking for a solution to that one, if there is one.
The manual states this about the av terminal.
Video: 1Vp=p/75ohms unbalanced
Audio: -10dbv(47kohm load) 3 ohms or less.
Lucky you suggested that about the terminal.. As i have only ued he headphones for an hour. What would you suggest i do?
Would any headphones work. What hardware would i need instead. Im already planning on buying one of those sign video beachtek type adapters. But ill still need the headphone out put. I do have a portable lcd tv about 2.5 inches. I could feed the A?V thru there and then plug headphones into that as a preamp. I dont think that would hurt.
Hmmmmmmmm
B.Sundry
Old November 27th, 2006, 04:32 AM   #9
Steve,
Was reading this post again. Basically i just need one of these boostaroo's.
If i go from the rca's on the av out cable. To stereo mini, to female/female stereo mini, then this should work and not take any load and fry my lil cam?
Let me know, but i think this is my cheapest and best option.
B.Sundry
Old November 28th, 2006, 12:20 AM   #10
Exactly - I've not had experience with that specific company, it just popped up on a google; but that's the way I'd do it. I'm still unclear what the comment about "3 ohms or less" means, but the boostaroo is designed to take consumer line levels and drive up to three sets of phones so it should cause no problems whatever... Steve
Old November 28th, 2006, 05:19 AM   #11
A firend told me that i shold be able to attach a filter to the cam with some tape to hold it in place.
He's probably right. If i can match the outer ring of the lens i could glue a filter spacer with that same diameter onto the front of the lens.
Old November 28th, 2006, 11:16 AM   #12
Often what appear to be screw threads are actually serrations to reduce flare and reflections. Before resorting to glue, take a look at the Cokin filter system at your camera store - as I recall they have some bayonet adapters and even options to mount a filter holder via a clamp ring that fits to the outside of the lens barrel.
Old November 28th, 2006, 12:22 PM   #13
Could the 3 Ohms be referring to the camera's *input* impedance?
Phil Sherwood is offline   Reply With Quote
Old November 28th, 2006, 02:00 PM   #14
I'll look into Cokin, thanks Steve, as afar as the ohms ive got no idea. I did use headphones once with the cam with no probs. But im not feeling like risking it again. Ill get a headphone amplifier like the one Steve suggests.
Old November 29th, 2006, 05:13 AM   #15
http://www.camcorderinfo.com/bbs/t127725.html
This post doesnt mention a preamp. Does everyone agree i will short out my cam if i dont frst put the output into a line level device and then amplify it ? Rather than a plugs only
