what filters to use on this audio?? at DVinfo.net
All Things Audio
Old November 2nd, 2006, 10:21 PM   #1
Need to clean up this audio but not real familiar with what filters to use. Give it a crack and school me on cleaning up this audio. BTW, it's for a recruit video I'm doing. Almost forgot, I'm using vegas 5.
Lalo Alvidrez is offline   Reply With Quote
Old November 3rd, 2006, 12:11 AM   #2
Here's an example of Adobe Audition's noise reduction plugin. I used two passes: the first to take care of the hiss, and the second to take some of those resulting watery stray-pitch noises out. It took under a minute. It's not the prettiest thing in the world but I think you can see how some tweaking could sound great.
Just realized you said you were using Vegas - sorry, I don't know the program! Audition is worth the investment, though . .
Abe Dolinger is offline   Reply With Quote
Old November 3rd, 2006, 11:56 AM   #3
Abe, that sure did sound a lot better. That's exactly what I'm looking for. If I don't get any responses from vegas users then I may go with Auditions.
Old November 3rd, 2006, 01:06 PM   #4
Lalo, Vegas does not include a noise reduction plugin. However, Sony does sell one of the best NR plugins available.
Other alternatives include the freeware/open source Audacity software, http://audacity.sourceforge.net/ which includes a basic NR plug. Many people seem to like Soundsoap for NR, I've not used it or Audition.
Old November 6th, 2006, 10:42 AM   #5
Thanks Seth, I'll give it a look.
Old November 6th, 2006, 01:20 PM   #6
GoldWave
Also try Goldwave. You can download a trial for free, and it's not expensive to buy. (Under $50 USD.) Here's the process:
* Open your clip in GoldWave. It supports 16 & 24 bit waves.
* Select a portion that has nothing but the noise that you want to remove. Copy it to the clipboard. (Ctrl-C)
* From the menu Effects > Filter > Noise Reduction. Select "Clipboard". I've been using 75% reduction with good results.
* Process the audio
* Save As
The UI is a bit primitive and not very attractive, but the above process is all you need for noise reduction.
Give it a try!
http://www.goldwave.com/
Jon Fairhurst
Old November 8th, 2006, 09:53 AM   #7
Thanks Jon, I have downloaded it and will give it a shot tonight.
