dvx100b XLR connector pins at DVinfo.net
All Things Audio
Old October 20th, 2006, 02:39 AM   #1
I am going to get a balanced cable (for my dvx100b and Rode NTG-2) and it will be custom-made (around 10meters)
pin layout of NTG-2 is documented as :
pin 1 ground
pin 2 (+)
pin 3 (-)
Pin numbers on the dvx100b XLR socket can be seen, but I suspect if dvx100b uses the same pin layout. finally, I need to know which wire to connect to which pin.
I also need some advice on the cable specs.
any info about this subject is valuable for me.
thanks
Baris Ustun is offline   Reply With Quote
Old October 20th, 2006, 06:27 AM   #2
pin 1 ground
pin 2 (+)
pin 3 (-)
thanks
Such cables are readily available premade at very low cost even for premium quality Star-Quad but if you do want to make up your own, one end will have a male XLR and the other a female XLR. Simply connect pin 1 to pin 1, pin 2 to pin 2 and pin 3 to pin 3. Just for reference, if you're making up balanced XLR to balanced TRS cables, XLR 2 goes to TRS tip, XLR 3 goes to TRS ring, and XLR 1 goes to TRS sleeve.
Old October 20th, 2006, 07:31 AM   #3
Thank you Steve for your reply.
